Box for 2 10" SA's - Car Audio Classifieds!
Old 03-18-2012, 10:10 PM
99technine's Avatar
0/11 ssssss399
Default Box for 2 10" SA's
Im waiting on getting a recone for one of the subs right now and i havent even started designing a box for them yet. I have an Acura Integra. 2dr hatchback. Im going to be running 2 10" Sundown SA's on about 2000 rms. Im planning on putting subs forward port forward. I want to use Aeroports. I want to tune it to 36hz in about 3ft^3.
First question i have. Should i use 1 or 2 flared aeroports?
Second. Should i tune it to 36hz in 3ft^3?
Third. Would subs forward/port forward be the best option?
Any help at all appreciated, thanks in advance.
Rep- MN [952]
Old 03-19-2012, 06:35 PM
duff_thrust's Avatar
0/11 ssssss629
You want output and power handling and a wide array of frequency response? Bandpass is where it's at
Old 03-20-2012, 11:46 AM
99technine's Avatar
0/11 ssssss399
Im not sure why i just dont like bandpass at all.. and i wanna try the flared aeros. Can you help answer any of my Q's?
Rep- MN [952]
Old 03-20-2012, 08:29 PM
0/11 ssssss629
Yessir, shoot.
Old 03-20-2012, 08:33 PM
0/11 ssssss629
The reason I suggest bandpass is because of it's output and response. They have a frequency range that drops low low (depending on front tuning) and they are nearly just as loud from the low cutoff all the way to the high cutoff. So music sounds AWESOME IMO in a 4th order. Plus they are usually more efficient and higher output than any standard ported enclosure while still retaining cone control (depending on space and ratio)
Old 03-20-2012, 09:39 PM
99technine's Avatar
0/11 ssssss399
K well saying i dont want a bandpass can you answer my original Q's
Rep- MN [952]
Old 03-20-2012, 09:54 PM
0/11 ssssss629
dimensions? and are you planning on dropping the seat and running subs and port into the cabin?
Old 03-20-2012, 09:58 PM
99technine's Avatar
0/11 ssssss399
Dimensions of trunk or box? I plan on folding down the seats when im bumpin them but not taking the seats out or building in the cabin or anything. I forgot to mention that i do plan on trying to compete a little bit with these for fun
Rep- MN [952]
Old 03-20-2012, 10:00 PM
0/11 ssssss629
max dimensions you'll be able to build a box in the trunk opening behind the seat.
Old 03-20-2012, 10:05 PM
99technine's Avatar
0/11 ssssss399
W-32" H-18" L-24" max trunk dimensions
Rep- MN [952]
Sundown SA's - Post your SPL Scores! Oldbass38 (Sundown Audio) 191 05-29-2012 06:15 PM
2006 Dodge Ram Big Horny 8 10" Sundown SA's dasinde91 Build Logs 13 10-16-2011 06:39 PM
Mmats P3.0's vs Sundown SA's Oldbass38 General Car Audio Discussion & Questions 2 08-29-2011 10:33 PM
how do the SA's do in 4th orders burzendowski (Sundown Audio) 11 08-19-2011 08:03 PM
Need 4 12" SA's Werner D. (Sundown Audio) 5 04-06-2011 02:35 PM
