removable port help - Car Audio Classifieds!
Old 03-19-2012, 01:58 PM
BASSNUT
0/11 ssssss180
Default removable port help
so i'm working on designing a box for a 10 and I want to try a removable port. my question is how do i support the port inside the box without gluing it? I guess it could still get screwed in but other than screws how does it get supported?
Old 03-19-2012, 01:59 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Use aeroports. Then you can easily play with the tuning by getting longer/shorter tubes to attach the flares to.
Old 03-19-2012, 09:13 PM
BASSNUT
0/11 ssssss180
I wanna use a slot port; they sound better imo.
Old 03-19-2012, 09:37 PM
btsteinb's Avatar
0/11 sssss3573
Ported Box 4 Re Mt 18s (my Current Box) Updates, More Pics 4-21-07 - SMD Forum
about half way down. In his 4th post. threaded inserts and weather stripping.
Old 03-19-2012, 09:56 PM
BASSNUT
0/11 ssssss180
That is exactly what i need. Thank you very much and btw, that looks amazing!
Old 03-19-2012, 10:04 PM
btsteinb's Avatar
0/11 sssss3573
Yea living in the UP gives me a lot of spare time to read. Check out some build logs on the various forums, you'll learn some cool tips and tricks.
Old 03-28-2012, 04:53 PM
psychoacoustics's Avatar
Veteran Member
0/11 sssss3830
Feedback Score: 50 reviews
Port area is port area
A round port will have the least turbulent air and work the best
A square is next and a rectangle being the worst then if that rectangle is long and narrow it gets even worse
Removable Aeroport Testing ? britdevine Enclosure Discussion & Design Construction Help 2 03-31-2011 04:35 PM
Removable port disatvantige? Russellabt General Car Audio Discussion & Questions 2 03-21-2011 02:17 PM
new box with removable port burzendowski Build Logs 7 07-30-2010 03:15 PM
removable battery, best way to do it? Anton Miller General Car Audio Discussion & Questions 1 04-28-2010 09:45 PM
Removable Ports? null_void General Car Audio Discussion & Questions 19 09-24-2009 04:21 PM
