Need help with tuning. - Car Audio Classifieds!
Old 03-19-2012, 02:04 PM
Austin175's Avatar
0/11 sssss4224
Question Need help with tuning.
Ok so I'm having SacTownbully building my box for 2 15" sundown SA's on a Skar 1500.1d tuned to or as close to 35 for rap an what not.
Now I want to add a removable port to the box because I listen to metalcore or as well but I don't know what's a good tuning area for this music. Can you guys help me with this I was think around 40 on the removable port would be good.
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 03-20-2012, 12:25 AM
Austin175's Avatar
0/11 sssss4224
Bump.
(caco),
Old 03-20-2012, 12:42 AM
SketchUp Master
0/11 ssssss417
Don't bother changing the tuning with swappable ports. All you'll be doing is making each port less efficient along with adding a nasty peak with the 40hz tuning as well as a higher group delay in the kick-drum range.
Old 03-20-2012, 01:01 AM
Austin175's Avatar
0/11 sssss4224
Ah ok well this is what the box dimensions are 15"T X 30"D X 40"W with 3 6" areo ports that are 15" long tuned in the 36-37 range. I was just wanting to find out what tuning is good for metal.
(caco),
tuning? slowpoke General Car Audio Discussion & Questions 4 09-17-2011 12:03 AM
h/t tuning ? alexis8284 Enclosure Discussion & Design Construction Help 9 09-11-2011 02:05 AM
tuning Austin175 General Car Audio Discussion & Questions 4 06-10-2010 08:01 PM
Need a little help with tuning 528hz Enclosure Discussion & Design Construction Help 2 06-10-2010 03:42 PM
tuning Fosgate1 General Car Audio Discussion & Questions 18 07-14-2009 09:23 PM
