Will this port work well? - Car Audio Classifieds!
Old 03-19-2012, 10:46 PM
0/11 ssssss161
Default Will this port work well?
Okay making sure my aeroport will fit in my box leaving enough space from the bottom of the box. (see attached picture)
6" round aeroport
12.7" long for 33hz tuning in 4.35 cu after DD9515h displacement
As shown in this picture at 13" long there is around 3" of space until the wall of my box, is this enough space in order to keep from distortion and damage?
suggestions?
are any 45 degree angles needed in a wedge box with aeroports? Is it okay to have the port at an angle?
Just a couple little questions I have, first attempt to use an aeroport.
Old 03-19-2012, 11:10 PM
duff_thrust's Avatar
0/11 ssssss629
having the port at an angle won't effect anything. However as a rule of thumb you'd want the inside mouth of the port atleast the diameter of the port away from any walls. So 6+ inches.
Old 03-19-2012, 11:20 PM
0/11 ssssss161
so it's completely impossible for me to use an aeroport then? I have no room outside the box..can you add turns in the port like on a slot port against a wall?
*PICS* Dual 10" Aero's. sub up/port up VS sub up/port forward Magnet General Car Audio Discussion & Questions 16 06-13-2011 03:24 PM
~143^2 Aero Port vs 235^2 Slot Port for 21 net cube enclosure VOPA1 Enclosure Discussion & Design Construction Help 6 12-02-2010 05:03 PM
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
Sub/port up in a trunk: does it work for daily? 1ndatrunk Enclosure Discussion & Design Construction Help 11 08-17-2010 11:04 AM
Will external slot port work good? westman995 Enclosure Discussion & Design Construction Help 2 04-12-2010 08:10 PM
