Trunk Guys Need Help? - Car Audio Classifieds!
Old 03-22-2012, 02:29 PM
0/11 sssss1801
Feedback Score: 17 reviews
Default Trunk Guys Need Help?
So I have just got the other sub to start my project.It consists of 2 15" dc xl 15s(d2) on a dc 3.5k for now.The car is a 2008 civic si sedan.My question is I wanna build a box that will play in the lows but still put up a good number maybe 48-50.My box now is sub up port side which seems to work or I could either go that way or do subs forward port side.Only reason I dont wanna do forward firing into cabin is im not going to seal it off.So which has proven it self and with what I got get pretty loud?
Pics up later of car.
Old 03-22-2012, 07:59 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Can you even fit (2) 15's in a daily back there? That's a lot of box to go any other way than subs/port forward.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 03-22-2012, 09:26 PM
0/11 sssss1801
Yeah before displacement. I have 8 cubes to work with and still slide box in
Old 03-22-2012, 09:27 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
How much clearance betwen the baffle and rear deck/trunk lid with that 8 cubes?
4x world champ
- Floyd E. Toole
Old 03-24-2012, 12:25 AM
schrummy's Avatar
0/11 ssssss288
X2 /\/\/\/\/\
2 15s is probably too much for daily for lows and still meter high... i know that i throw up 53s on the dash with 2 12s subs forward and port to the side.... i just have my box as far back as possible.... also, that 53 is at 61hz.... Anton is doing 49+ with 2 12s forward port side and under 40hz.....
we both have cavaliers....
150 db @ 33hz
Team Midwest
Old 03-24-2012, 12:28 AM
sleepingciv's Avatar
0/11 sssss1936
Feedback Score: 31 reviews
2 sa15s here firing into cabin not sealed off side ports tad over 7 cubes. 93 civic coupe
not done so no pics
Old 03-24-2012, 11:50 AM
Quick's Avatar
0/11 ssssss229
I have a 95 civic coupe n wanted to do the same setup in my trunk with the sa15s.. how's it sound, what power u got and any numbers or anything yet?
Anyways I had 2 15s before in the trunk but had to do sub up port to the side. Instead of building in the trunk I wanted to fit through trunk or backseat opening.. Got loud but slacked on the low end..
Sent from my Motorola Electrify using Tapatalk
'00 Maxima 5-Speed
Sundown Audio 6.5" Components
Treo SSX40.4
Single Sundown SA-12
Soundstream Trx2000d
Audio Technix 0awg
Old 03-27-2012, 02:13 PM
0/11 sssss1801
Meaning can I close the seats?Max height would be 17 I'm only going with 16 but might do a spl box instead
Old 03-27-2012, 02:23 PM
0/11 ssssss102
I have an 08 ex, subs and port forward is the loudest you will find for the new gen civics. The box I used was only 14.5" with the face slanted back to fit the 15s with a big slot port in the center.
Old 03-27-2012, 02:26 PM
0/11 sssss1801
Any pics might have to tryhow bigwas box
Trunk 0-1000w Class RUN....LOUDEST TRUNK EVER Skip01 Car Audio Videos 270 04-30-2012 09:54 PM
Trunk guys what you think? 99Bonney General Car Audio Discussion & Questions 29 02-16-2012 08:31 AM
i wonder if this guys trunk rattles? bassisgood General Car Audio Discussion & Questions 39 05-05-2011 02:19 PM
4 door trunk car - cant use trunk ... brian84corvette Enclosure Discussion & Design Construction Help 23 10-13-2010 09:24 PM
Sealed off, Firing into the cabin Trunk Guys 528hz General Car Audio Discussion & Questions 11 07-29-2010 06:10 PM
