4th order design for one sa10 - Car Audio Classifieds!
Old 03-23-2012, 05:51 PM
0/11 ssssss443
Default 4th order design for one sa10
can some help me design or how much airspace i should have
Old 03-27-2012, 02:41 PM
0/11 ssssss840
.5 sealed and 2.5 ported
Mod 0-1000
Team Db Driven
Team B2 audio
Team Tantric Sounds
2012 SB1 World Champion and World Record Holder
0-1000 World Record Holder
Old 03-27-2012, 02:47 PM
0/11 ssssss443
what would you tune it too its going in a trunk
Old 03-27-2012, 02:59 PM
813thumper's Avatar
0/11 sssss1116
If you are wanting to run this daily and have a wide bandwidth, I would stray away from a huge ratio like what was suggested. I would go .5-.7 sealed and 1.5-2 ported. Port area and tuning are going to depend on what type of response that you are wanting. Depending on what your listening goals are, you may be better off with a standard ported enclosure.
I LIKE BUILDING ENCLOSURES FOR CUSTOMERS
Old 03-27-2012, 03:58 PM
0/11 ssssss443
ok so around 33hz tunning be good.yea i have in a ported box tuned to around 32hz it sounds good i just want to give a 4th order a try to see how it will sound thanks
4th Order Design Help Silver-N-black Enclosure Discussion & Design Construction Help 9 08-24-2011 01:23 PM
First 4th order design AFlem Enclosure Discussion & Design Construction Help 20 04-29-2011 10:42 PM
4th order design 3rdshiftdiscretion Enclosure Discussion & Design Construction Help 20 01-25-2011 10:09 PM
how to design 4th order xcaliber Enclosure Discussion & Design Construction Help 11 12-11-2010 06:48 PM
4th order design spl-101 General Car Audio Discussion & Questions 13 08-22-2010 07:05 PM
