S14 240sx 12" enclosure help - Car Audio Classifieds!
Old 03-25-2012, 01:22 PM
0/11 sssssss46
Default S14 240sx 12" enclosure help
Hey,
This is my first time attempting an enclosure and this is what I have marked up. Would you great people of CACO please check my dimensions and tell me if I have derped anywhere or where I can improve?
My trunk is awkwardly spaced so I have a max usable space of 50" W x ~12" D x ~12"H; the box I've made is 30" x 11.5" x 12" (on the exterior)
It will be hosting a Sundown Z v.3 12" and am hoping for ~ 33Hz. I'm planning on making it out of 3/4 MDF.
Here are my dimensions for MDF pieces:
Base: 30" x 11.5"
Left side: 10"
Back: 30" x 11.25"
Right side: 10.75" x 11.25"
Inner port wall: 7.75" x 11.25"
Inner Supports (x2): 2" x 11.25"
Top: 30" x 11.5"
Old 03-25-2012, 05:55 PM
bigdogjk's Avatar
Bigdogjk Designs
0/11 ssssss226
You won't be able to fit a 12" sub in that box. The over all width of the speaker is 12 5/8", so you need to go 13" high.
I also plug your numbers into my program and it's 1.2^ft tune around 59hz (after sub displacement)
The Following User Says Thank You to bigdogjk For This Useful Post:
240FAP (03-25-2012)
Old 03-25-2012, 06:00 PM
0/11 sssssss46
Thanks. I'm way off I guess. I can't go any higher really. The only room I have to is wide.
hmm. anyone have any ideas on another design?
Old 03-25-2012, 06:12 PM
Loyal Member
0/11 sssss2152
Feedback Score: 35 reviews
The 240 is a hatchback isn't it?
I'm just gonna ask my landlord to hold the car up while I take the tires off. I mean, she's old and all but should be okay.
Old 03-25-2012, 06:38 PM
bigdogjk's Avatar
Bigdogjk Designs
0/11 ssssss226
You may have to go with an angle / wedge box. I'll look at see if I can find some pics and see what others have done.
Old 03-25-2012, 06:54 PM
0/11 sssssss46
Nope, It is a S14. I'll reference this thread for some better pics of it and dimensions:
Old 03-25-2012, 07:40 PM
bigdogjk's Avatar
Bigdogjk Designs
0/11 ssssss226
I started to design a forth order box for him, but he ended up doing something else.
Here is the diagram he had posted on the other trend.
He also said he could go another half an inch wider,deeper and higher. You should have room for 44"W x 14"D x 13" to 14"H (he went with 12"H to have more room for the air to go over the box)
Go take some measurements yourself and see what you can fit.
Here are a few others pics I found with 12"s in them. The 1st 2 pics still has the spare tire in there. The 3rd uses the spare tire well for the box.
Here is the box he had in there.
This box is 44"W x 11 1/2"D x 12"H
Old 03-25-2012, 08:50 PM
0/11 sssssss46
Thanks again.
I'd prefer to keep access to the spare tire.
I didn't think about reverse mounting the sub.
So of I expanded my current design to the right dimensions, should I be fine?
Sent from my phone.
Old 03-25-2012, 11:53 PM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
Wow I thought I was the only one on the forums with that car.
We have the same car. Mine is a 95 w/ 22k miles.
I took my spare tire out, and have batteries down there. MDF floor built over it to flatten everything out.
Heres my latest idea..
Almost 6 ft^3. Box will be built inside the trunk, and will be the WHOLE trunk. I will even have to make 2 spots in the box like slots/cutouts for the trunk hinges.
It will be loud though
The last box that bigdogjk has a picture of is the BIGGEST box you can fit into the trunk and still remove. I spent a long time getting those measurements correct, and I promise you cant fit anything bigger w/o building it inside the trunk.
You actually have more height than you think you do. If you stay far enough back from the trunk hinges (make sure to account for where they move up/down) you have 13+". If you dont believe me, climb in the trunk and have your friend shut you in there with a tape measure like I did. haha
Old 03-25-2012, 11:55 PM
0/11 sssss2271
Bigdogjk, do you have any input on my latest quest? To fit 6 SA 8s in a 4th order? Go check out my thread please. I started in google sketchup but not sure if what I did is OK or not, and I have some questions. Have you designed boxes for SA 8s before, or any 4th orders?
help with first time "REAL" box in 240sx hatch joemon Enclosure Discussion & Design Construction Help 23 05-03-2012 08:36 PM
4 SAs in 240sx KTMrida4life Enclosure Discussion & Design Construction Help 16 01-15-2012 05:43 AM
240sx Wall, two 15s, 4500w LyferXB9s Miscellaneous Build Logs 67 08-11-2011 07:04 PM
Mid/Tweeter "cups"/"covers"/"enclosure"/"etc"??? oxsign General Car Audio Discussion & Questions 11 04-21-2010 04:29 PM
Nissan 240SX wiring harness FS canyouhearmatt Wiring, Electrical & Other Installation Equipment 0 01-21-2009 03:37 PM
