how to drill holes in plexiglass? - Car Audio Classifieds!
Old 03-28-2012, 02:33 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Default how to drill holes in plexiglass?
I am looking at putting a window into a 6th order that WW is designing.
I have seen tutorials on drilling holes through 1/8 in thick plexi, using progressively larger and larger bits.
Just wondering if it would be any different for 3/4 inch thick, because it is so thick, would heat and warping/melting/easier cracking be a problem?
I plan on using 1/4" bolts every 2 inches on the plexi and the sealing it with silicone.
Any suggestions to this are appreciated.
Old 03-28-2012, 02:43 PM
jmelton86's Avatar
Something clever.
0/11 ssssss626
Go very, very slowly.
I don't recommend going larger and larger with the bits, because if one of them catches, it could crack/ break the plexi.
CDA-9855 PDX4.100 GTO14001
Tuning low is great.
KeepItSimpleStupid
Old 03-28-2012, 02:45 PM
sleepingciv's Avatar
0/11 sssss1936
Feedback Score: 31 reviews
yup slow is the key and one size bit.
Old 03-28-2012, 02:48 PM
btsteinb's Avatar
0/11 sssss3573
should i bite the $20 and get the special bit, or would a metal bit work fine?
Old 03-28-2012, 02:54 PM
0/11 sssss1936
i just use metal bit, never knew there was a kit.
just make sure ya stay straight while drilling
Old 03-28-2012, 04:09 PM
Matt3824's Avatar
0/11 sssss3754
To me the 20 bucks would be worth it
Old 03-28-2012, 04:13 PM
0/11 sssss1250
Feedback Score: 34 reviews
what would getting the special bit do better at?
SPL-Lab REP
Want an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has more features and more support? PM me.
Old 03-28-2012, 04:14 PM
tacomaguy1's Avatar
0/11 sssss4401
like drilling in glass? can you do that with a metal bit?....it would be the same concept, they have bits for drilling glass and I think they have bits for drilling plexiglass
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 03-28-2012, 04:25 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
There is a plexiglass bit.
Sent from my HTC EVO 3D
Old 03-28-2012, 04:29 PM
0/11 sssss6075
Use Lexan.
drilling holes JAYARE2007MAG General Car Audio Discussion & Questions 3 10-19-2011 07:22 AM
CL a-holes bones22 Off Topic Chat 7 06-06-2011 11:13 AM
Is it necessary to pre-drill holes in birch? 87linkin General Car Audio Discussion & Questions 21 09-21-2010 03:00 AM
Mother of all sink holes kmanian1 Off Topic Chat 62 06-01-2010 08:10 PM
Drilling new basket mounting holes? Inferno333 General Car Audio Discussion & Questions 9 11-22-2009 08:30 PM
