3/4" birch vs 1/2" birch - Car Audio Classifieds!
Old 03-29-2012, 01:41 PM
doug118's Avatar
0/11 sssss4674
Default 3/4" birch vs 1/2" birch
I've rear through all of the birch threads and saw a couple of people say 1/2" birch is just as strong as 3/4" mdf. How many people have been able to use 1/2" birch? I'm getting ready to build a 4th order and 3/4" birch is $59.99 per sheet locally. I'm only running 2 sa-12's on ~1500 watts. Will 1/2" hold up or do I need 3/4"?
Old 03-29-2012, 08:53 PM
kmanian1's Avatar
mine>yours
0/11 sssss2130
1st do NOT believe 1/2" is as strong as 3/4"
2nd it is much harder to shoot a nail or drive a screw into the side of 1/2" without having a shiner
3rd, your glue surface is 33% less with 1/2 than 3/4.
So in short, don't cheap out, get 3/4"
The Following 2 Users Say Thank You to kmanian1 For This Useful Post:
art1618 (03-29-2012), doug118 (03-29-2012)
Old 03-29-2012, 08:55 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
If you are worried about price get cabinet grade plywood, (accuro-ply) at most stores. It's all I use, and I know a lot of other people that use it, normally $30ish for a sheet.
The Following User Says Thank You to btsteinb For This Useful Post:
TaylorFade (03-29-2012)
Old 03-29-2012, 08:58 PM
fiji24's Avatar
0/11 sssss1826
If price is such and issue just get MDF, but if you want birch then just get the 3/4th...
2003 Chevy Trailblazer
Subs- 4 Fi Q 12's
Amps- Sundown 3500D & Rockford Fosgate Power T400-4
Mids- 2 Peerless 6 1/2's Nomex Cone HDS Woofer
Highs- 2 Bohlender Graebener Neo8-PDR Planar Transducers
Headunit- Alpine CDA-9835(ACTIVE)
Old 03-29-2012, 10:06 PM
doug118's Avatar
0/11 sssss4674
my box is 8 cubes going into a honda, there is no way I'm using mdf. I didn't think about nailing and gluing a 1/2" piece vs 3/4". That's more then enough to spend the extra $
Old 03-29-2012, 10:15 PM
0/11 sssssss66
Cabinet grade plywood is the way to go. I made similar size boxes one with mdf and one with cabinet and the cabinet was 30 lbs lighter.
Old 03-29-2012, 10:16 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
This.
It's all I use. Cheaper and lighter than MDF.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 03-29-2012, 10:19 PM
kmanian1's Avatar
mine>yours
0/11 sssss2130
I have used Concrete form ply on a few boxes recently and really like it! it hold a screw like nobodies business, cuts good, and sounds pretty dead.
Old 03-29-2012, 10:20 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Yeah? How much? Where'd you get it?
4x world champ
- Floyd E. Toole
Old 03-29-2012, 10:28 PM
kmanian1's Avatar
mine>yours
0/11 sssss2130
local hardware store, kinda like Home Depot. It is commonly called "Red edge"
Here MDF is $50 per sheet, and red edge is $42
wtt birch 10" for hu tankglh21 Car Audio Trader (WTT) 5 05-31-2011 02:24 PM
4 15" audioque sdc2.5 in birch box MYTRUNKSLAMZ 15" Subwoofers 18 12-02-2010 03:23 PM
FS: AMI built birch 2 12" enclosure loud-n-low Wiring, Electrical & Other Installation Equipment 5 10-05-2010 04:47 AM
15" subwoofer enclosure CHEAP BIRCH!! Mendon Mafia Wiring, Electrical & Other Installation Equipment 11 08-23-2010 10:39 AM
F/S - Quad 10" Enclosure (Birch, 6" Aeros, Vinyl) SundownAudioNY Wiring, Electrical & Other Installation Equipment 11 06-29-2010 08:01 AM
