port help please - Car Audio Classifieds!
Old 03-29-2012, 04:42 PM
scfaust's Avatar
0/11 ssssss848
Default port help please
ok im going to use this box here------------------
open torres and try these specs:
h = 15
w = 36
d = 19
port dims:
3 common walls
h = 13.5
w = 3.5
l = 24
misc specs:
woofer displacment = .28
specs:
3.57 cubes
13.24" of port per cube
47.25 total port area3.5 cubes
33-35hz
about 12-14" of port per cube
h = 15
w = 36
d = 19
port dims:
3 common walls
h = 13.5
w = 3.5
l = 24
misc specs:
specs:
3.57 cubes
this is the box im going to use but i need to know how to do the port bend to make it add up right can anyone help me out with this please
now i need help with the port ? is the port should go in 14.75 and bend and then another 5" to be right. if thats not right can someone help me please
screen shots
http://i1095.photobucket.com/albums/...lett/Box-1.png
AlphaDamp CLD Tiles - Get more sound deadening using less sound deadener
Old 03-29-2012, 04:47 PM
0/11 ssssss443
where is the port facing
Old 03-29-2012, 05:03 PM
scfaust's Avatar
0/11 ssssss848
back
it will be
h = 13.5
w = 3.5
l = 24
and the 24 has to be bent thats y i need to know L of first port cut and L of second port cut
Old 03-29-2012, 05:07 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Just measure the center line of the port keeping the same distance from the wall the whole way.
Your box is 19" deep. Your port is 24" long and 3.5" wide. So, centerline needs to stay 1.75" off of the wall. Centerline to the first turn should be 17.25" (with your panel cut being 16.5"). Add the .75" for the panel and the 1.75" (other half of the port) make another panel 4.25". That'll do it.
Effective port length there will actually be 25.75" because of the common wall, but I just use that as a fudge factor. If you're concerned with it, make the 2nd panel 2.5"
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 03-29-2012, 05:11 PM
niteryda's Avatar
im "E Thug" sukka
0/11 sssss3259
wel since the port is on 1 side, if u make the first port wall screw into the baffle from behind then u will take ur 19", subtract 1.5" (.75" for front baffle n .75" for back wall), ur left with 17.5", now subtract ur width (3.5") ur left with 14", so ur first part of the port should be cut to be 14" long n 13.5" high, which is the physical port cut out, so 19.75" minus the 14" u just cut is 5.75" so ur 2nd cut for the bend of ur port should be 5.75" long n 13.5" high, u screw the shorter piece into the longer piece by the side of the longer piece, if i confused the snot out of u just let me know
2000 Pontiac Sunfire SE (239,000+ miles)
2 AQ3500D.1 (1 being used so far)
4 15" Nightshade v1
4 15" FI BTL N2 (1 being used)
3.5 net @ 29hz
3 crescendo 1000c4 (1 being used so far)
Bought From - Lots of people
Sold To - Myself
Traded With - DevinG17
The Following 2 Users Say Thank You to niteryda For This Useful Post:
Carlos12 (03-29-2012), scfaust (03-29-2012)
Old 03-29-2012, 05:14 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Here's a stupid paint drawing. Thin lines being the centerline of your port and the bold the panels. That diagonal red line represents effective port length.
[Edit: Depending on how you actually assemble it, don't forget to account for the thickness of the baffle in the port length.]
4x world champ
- Floyd E. Toole
Old 03-29-2012, 07:22 PM
scfaust's Avatar
0/11 ssssss848
ok if i want to do something crazy like this ports how do i figure it out
Old 03-29-2012, 07:36 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Get a tape measure, a pencil and a calculator, man.
4x world champ
- Floyd E. Toole
Old 03-29-2012, 08:54 PM
scfaust's Avatar
0/11 ssssss848
ok screw that then i cant get nuff port area with them
Old 03-30-2012, 12:30 AM
niteryda's Avatar
im "E Thug" sukka
0/11 sssss3259
Idk how to do the triangle ones, like it might be the same as a having a square port then just cut in half diagnally n ur good, or if u cut diagnally u have to add a lil more length, but to check for port area of a triangle, its base times height divided by 2, the base n height r the 2 shorter legths of a right triangle, there ya go ;-)
4 15" Nightshade v1
3.5 net @ 29hz
Sold To - Myself
SPL box... Slot port? Port Tube? Kerf? CousinVin Enclosure Discussion & Design Construction Help 13 07-21-2011 02:41 PM
*PICS* Dual 10" Aero's. sub up/port up VS sub up/port forward Magnet General Car Audio Discussion & Questions 16 06-13-2011 03:24 PM
~143^2 Aero Port vs 235^2 Slot Port for 21 net cube enclosure VOPA1 Enclosure Discussion & Design Construction Help 6 12-02-2010 05:03 PM
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
