Does this 4th order design look good? - Car Audio Classifieds!
Old 04-03-2012, 01:14 PM
get_low's Avatar
I like tater tots!
0/11 ssssss951
Default Does this 4th order design look good?
What I'm shooting for is all around listening, from lows to 40's in the HZ range. I have a 15" AA havoc and 1500rms to feed it. This will be going into the trunk of a 300c. I can make the box MAX 32wX17.5tX20-25d.
This is what I came up with.... 1.5sealed, 3ported tuned to 45hz?
This was my first attempt at trying to design a 4th order, so it's probably a bad design lol.
[email protected] sealed legal
Old 04-03-2012, 01:17 PM
0/11 ssssss518
you might want to go a little bigger that 1.5cu ft on the sealed side
Old 04-03-2012, 01:19 PM
get_low's Avatar
I like tater tots!
0/11 ssssss951
And keep the ported side the same?
Old 04-03-2012, 01:23 PM
0/11 ssssss518
yeah dont get to hung up on ratios, id reccomend tuning to 45 as well with the same port area
i had a 1:1 fourth 2cuft sealed 2cuft ported it worked great
4th Order Design Help Silver-N-black Enclosure Discussion & Design Construction Help 9 08-24-2011 01:23 PM
First 4th order design AFlem Enclosure Discussion & Design Construction Help 20 04-29-2011 10:42 PM
4th order design bassbear007 General Car Audio Discussion & Questions 1 02-17-2011 08:57 PM
Good 4th order wall design for 4 18" LVL4's Josh Wahlie General Car Audio Discussion & Questions 1 01-26-2011 01:45 AM
4th order design spl-101 General Car Audio Discussion & Questions 13 08-22-2010 07:05 PM
