Single 6" for 2 12's on 4k? - Car Audio Classifieds!
Old 04-03-2012, 08:37 PM
trf7196's Avatar
0/11 sssssss54
Default Single 6" for 2 12's on 4k?
I'll be running a crescendo bc3500 at 0.5 on 2 RD Audio Alpha V2 12's reconed by PSI so roughly 4k or so of power. I was gonna do 4.14 cubes net tuned to 35 hz with a single 6" aero. My question is will a single 6" be fine and will I have any port noise? Vehicle will be a trunk car firing forward sealed off and yes the seats fold down.
Old 04-03-2012, 08:50 PM
scfaust's Avatar
0/11 ssssss848
ive been asking around and i was told u will get port noise if the port is to close to the back of box like if its 6" u need to stay 6" from wood also same for the port being to close to trim trunk ext outside box, and if u dont have recomended port per sq ft. it may not be right. so check all that
AlphaDamp CLD Tiles - Get more sound deadening using less sound deadener
Old 04-03-2012, 08:53 PM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
How long do you plan on the port being? I just went through something like this for a trunk box I'm trying to design and have a 6" to work with as well and I'm going to end up doing a kerfed slot port because I can't get enough port area per sq. ft in my box...will be about 3.5 after displacements and for my tuning (30 hz) I can't get past about 7 sq in per ft in my setup. Good luck
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
Old 04-03-2012, 08:59 PM
Ajax_6154's Avatar
i want more bigger db's
0/11 sssss2369
im running a single 6" in 4.3 cubes at 32hz for my single 15 on a BC3500 at 1ohm and havent had a single issue. in fact i think its perfect. i was worried at first but i havent heard a single bit of port noise or anything... you should be fine
Vehicle: 2011 VW GTI Autobahn
Deadning: 50sq ft of AT 60, Front Stage: CCX65 on a 1000c4, Sub: Eminent Audio EA1000 10's in 4.9ft3 at 35hz on a BC3500d at 1ohm
i dont like 12's they cant hit the lows like 10's
Old 04-03-2012, 09:01 PM
jhg33k's Avatar
0/11 sssss1531
How much port area per cubic ft is yours? I've been trying to learn about aeros so I'm gathering as much info as I can get lol...sorry OP, not trying to thread jack but trying to learn
Old 04-03-2012, 09:05 PM
cjvue's Avatar
0/11 sssss1028
You can probably get by with 6", but honest i like to see an 8" port with that power. (assuming you have the airspace to expend box dimension to accomendate the 8"). I have gone from 6" to 8" and have been much happier with output (especially 3k and above).
Old 04-03-2012, 09:09 PM
0/11 sssssss42
4.2 cubes with a single 6" aero is 6.73" per foot. 28.26" total area. 3.5 cubes with a 6" is 8.07" per foot and total area is the same. Keep in mind aeros do not follow the generic "rule of thumb".......
All measurements from Torres Calc.
Right now I have 2 12" psi's in my wifes fusion in 3.75 cubes on a American Bass 100.1 with 2 6" aeros tuned at 33hz firing back....it does decent. Rebuilding to fire forward with 1 6" in 3.5cubes.
2011 Meca World Champ S3 151.9
Ajax_6154's Avatar
0/11 sssss2369
i completely agree with this post. i did should have mentioned that i did not have room for a single 8" or i would have gone with that for sure
The Following User Says Thank You to Ajax_6154 For This Useful Post:
cjvue (04-03-2012)
Old 04-03-2012, 11:19 PM
trf7196's Avatar
0/11 sssssss54
Port is only 11" long and would be 6" away from back wall.
Old 04-03-2012, 11:23 PM
trf7196's Avatar
0/11 sssssss54
I can't do a single 8" aeroport. Lowest I could tune is about 40 hz or so and that ain't gonna fly. I wanna stick with a tuning of 32-35 hz if possible. Max dimensions are 36 wide by 16.5 tall x 20 deep. Everything needs to be firing forward. I could do slot ported tuned to 33 hz 4 cubes net with 13 sq in per cube but that would be my max dimensions. I'd like to do aeroported to make the box 2" shorter in depth.
WTB:2x Fi X 10" Single 2 --or-- 1x Fi SSD 12" Dual 2 its_bacon12 Wanting to Buy (WTB) 5 01-25-2012 12:22 AM
decent two 12's or single 15? Ujerk123 General Car Audio Discussion & Questions 10 11-13-2011 12:38 PM
WTB single 10" or 12" SQ subwoofer yourwhiteshadow Wanting to Buy (WTB) 6 06-23-2010 01:32 PM
[SOLD] 2 BNIB 10" Subs + Single 10" box + New Speaker Wire Jh8909 Car Audio Packages 6 02-15-2010 04:20 PM
12" and 15" single sub box needed!!! CTIPPINS Box Requests 3 01-10-2009 01:50 PM
