Is this a good box for SA 12's? - Car Audio Classifieds!
Old 04-03-2012, 11:11 PM
bokeson's Avatar
0/11 sssssss66
Default Is this a good box for SA 12's?
I came up with these specs for a box for my 2 sundown sa 12's. I was wondering if this would be a good design and just wondering if I should change anything. Subs up port back. any input would be awesome. thanks
Old 04-03-2012, 11:46 PM
bigdogjk's Avatar
Bigdogjk Designs
0/11 ssssss226
1st thing you should do is use Photobucket to host the picture.
imageshack has to many ads and uses to small of a picture to see the numbers
Old 04-04-2012, 08:14 AM
bokeson's Avatar
0/11 sssssss66
Fixed it.
Old 04-04-2012, 06:30 PM
bigdogjk's Avatar
Bigdogjk Designs
0/11 ssssss226
Looks good, what do you listen to?
Was you looking for 35hz tuning?
What amp or how much power you using?
What are you putting it in?
Can you make the box any bigger? If so what's the max dimensions you can go.
Old 04-04-2012, 06:38 PM
cjvue's Avatar
0/11 sssss1028
That looks good! Now get busy with the build...
Old 04-05-2012, 10:31 AM
bokeson's Avatar
0/11 sssssss66
i mostly listen to rap/ decaf. they will be on a sundown sax 1200d. and those are my max dimensions
Old 04-05-2012, 02:22 PM
bigdogjk's Avatar
Bigdogjk Designs
0/11 ssssss226
I would go with what you have enter or make the port 27.5" long to bring it down to 33hz and if you listen to alot of decaf, make the port 30.5" long to bring it down to 32hz.
It will also give a little more port area per foot. The net volume will go down a little but it will still be in a good range for 2 sa-12s.
I like using 3.5 to 4.5 cu ft for 2 sa-12s.
Old 04-05-2012, 02:26 PM
jt_buck's Avatar
don't shoot
0/11 sssss4424
What vehicle is this going in?
And if you are going to play decaf, I recommend tuning lower.
Old 04-05-2012, 11:14 PM
bokeson's Avatar
0/11 sssssss66
a 2000 jeep grand cherokee. and i think i'll drop the tuning to around 32hz
Is this box design good for 2 12's? 18inchbangin General Car Audio Discussion & Questions 0 06-26-2011 11:20 AM
05 RE XXX 12's (one good one for recone) SPY 12" Subwoofers 25 05-31-2011 09:42 AM
good 12's JAYARE2007MAG General Car Audio Discussion & Questions 3 03-28-2011 09:32 PM
[SOLD] Rockford Fosgate 12's - 1 good - 1 blown extreme Broken & Non-working equipment 4 11-30-2010 12:50 PM
DC level 3 12's... Any good for Lows? taylorpro (DC) 6 10-15-2010 04:13 PM
