best speaker wire terminal? - Car Audio Classifieds!
Old 04-03-2012, 11:05 PM
0/11 sssssss62
Default best speaker wire terminal?
Just finished a box build, and I really didn't want to put a plastic speaker terminal on the box for multiple reasons. Just ran wire through the port for now. I see a lot of guys using threaded rod, and I'm just wondering how good that method is, and how you properly seal that after. I'm open to any other suggestions as well.
On another note, is 8 gauge wire sufficient for running 1500rms to a single sub?
Any feedback is greatly appreciated, thanks in advance.
Old 04-03-2012, 11:16 PM
badmofo529's Avatar
0/11 sssss3329
i use brass bolts with a washer on each side to make sure its sealed.
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
The Following User Says Thank You to badmofo529 For This Useful Post:
channaman (04-04-2012)
Old 04-04-2012, 12:40 AM
doug118's Avatar
0/11 sssss4674
bolts with a washer and slap some silicone on the side of the washer that's going to be touching the box
The Following User Says Thank You to doug118 For This Useful Post:
Old 04-04-2012, 02:01 AM
Basshead
0/11 sssssss17
Default ...
just put silicone on the washers. and its prob a better method to use threaded rod then those plastic cup terminals. and 8 gauge should be fine, ive seen people use 16 gauge to a sub just fine. but bigger the better
Old 04-04-2012, 03:29 AM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
bolt terminals or just drill a small hole and run ur wire out of it then seal around wire
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 04-04-2012, 03:47 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Get brass bolts, washers for each side, nuts and a wing nuts. All brass.
Put ring terminals on the wires, hook it on the bolt, put a flat washer on, put it through the box from the inside, put the other flat washer on, put the nut on and tighten it down. Be careful, brass is fairly soft.
Then put ring terminals on your other wires, put it on the bolt and run your wing screw down.
Makes it easy to take off/change and transfers electricity fairly well.
And 8awg is more than enough.
Team CACO Team SHOK
Supporting Member
The Following User Says Thank You to 92K1500 For This Useful Post:
Old 04-04-2012, 08:52 AM
0/11 sssssss62
thats is the answer i was looking for, thanks a lot. /thread
Old 04-04-2012, 09:03 AM
thawaxshop's Avatar
0/11 sssss2506
Feedback Score: 48 reviews
I use these on all my boxes
Dayton Audio BPA-38G HD Binding Post Pair Gold 091-1245
misc wire 12 ga and 8ga speaker wire, speaker rings, bass knob financethis Wiring, Electrical & Other Installation Equipment 1 04-08-2012 11:23 PM
FS: 16 gauge speaker wire, speaker terminals, MDF speaker rings YouSirName Wiring, Electrical & Other Installation Equipment 13 02-12-2012 04:04 PM
FS: 14 gauge speaker wire, speaker terminals, MDF speaker rings YouSirName Wiring, Electrical & Other Installation Equipment 2 01-15-2012 11:36 PM
FS: used speaker terminal YouSirName Speaker Accessories & Parts 10 06-25-2011 09:03 PM
speaker terminal? poundstone General Car Audio Discussion & Questions 11 09-06-2010 08:35 PM
