Port Painting Tips? - Car Audio Classifieds!
Old 04-04-2012, 01:18 PM
0/11 sssssss62
Question Port Painting Tips?
Did my first box build this past weekend and painting the port proved to be an obstacle
Just wondering what the best method is.. I originally painted the pieces ahead of time. Taped off, 2 light coats of primer, and 4/5 coats of paint. However, after applying glue, and sealing the joints it's really hard to get in and sand and apply another few coats once it's all assembled to get a nice finish. Just wondering if you guys have any tips.. thanks in advance.
Old 04-04-2012, 01:47 PM
0/11 sssss3842
Gotta do it all before u finish the box
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 04-04-2012, 03:32 PM
BASSNUT
0/11 ssssss180
I always just do 2-3 light coats of valspar flat black spray paint, always covers nicely and leaves no streaks. I've never had to sand or prime, just make sure the port was clean of any sawdust or other particles
Old 04-04-2012, 03:41 PM
jmelton86's Avatar
Something clever.
0/11 ssssss626
I usually build the entire box, let everything dry, and then take a can of spray paint and spray the crap out of the port from the outside.
It takes an entire can, usually, but looks fine.
CDA-9855 PDX4.100 GTO14001
Tuning low is great.
KeepItSimpleStupid
Old 04-04-2012, 03:49 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Tape is the only way to prevent the glue from fuking up the finish if you do it before hand. Tape off the sprayed parts before assembly then do your glue up. Before its completely dry remove the tape and you should have a clean painted surface with no blemishes.
Old 04-04-2012, 03:53 PM
jt_buck's Avatar
don't shoot
0/11 sssss4424
Painting ports can be difficult. See, with the wood glue, if you don't sand, the color will look slightly different vs. where there isn't any wood glue. The paint will be glossier on the wood glue, so the key is try to keep that as clean as possible.
You also need to try to clear as much dust out of the enclosure as possible.
Old 04-04-2012, 04:25 PM
0/11 sssssss62
that's what I was looking for.. didnt think of it
what I'm trying to say fellas, is that after painting it all the glue runs out on the seams when I clamp everything together.. and there is no real way to spray the entire port after assembly, or to do it evenly at least. Thanks
Painting baskets? OldSchoolRF General Car Audio Discussion & Questions 6 02-25-2012 07:25 PM
Painting MDF? nicyousuckk Enclosure Discussion & Design Construction Help 21 02-13-2011 04:08 AM
any idea's for painting a slot port? [email protected] Enclosure Discussion & Design Construction Help 9 01-08-2011 11:16 AM
painting a box? tankglh21 General Car Audio Discussion & Questions 20 10-22-2010 11:17 PM
painting baskets???? Dunbar91 General Car Audio Discussion & Questions 12 07-03-2010 11:03 PM
