i need a wall/box design for 1994 accord! - Car Audio Classifieds!
Old 04-05-2012, 03:31 AM
0/11 ssssss378
Default i need a wall/box design for 1994 accord!
he i recently bought a 1994 2 dr honda accord im looking to do a wall with 4 15 inch skar audio subs can anyone design me a wall for these subs? i have paypal!
Old 04-09-2012, 04:04 PM
0/11 ssssss369
im looking for a wall design for 4 sa 12's aswell. Hopefully somebody posts, Free bump for u
Refs: Austin175, SkarAudio, Richard, ampaddiction, r1 banshee, wcjake15
Old 04-09-2012, 04:05 PM
0/11 ssssss369
i did do a little research and saw that Ram Designs, DonH, and jt buck do designs..i guess their worth a PM
Old 04-09-2012, 04:06 PM
0/11 ssssss369
Ram designs has a website too
RAM Designs - Home
Old 04-09-2012, 09:23 PM
Build out what you can first (e.g., the "back" of the box) and then measure. It's going to be virtually impossible for someone to design you a wall that big without having exact dimensions for every angle. You will almost definitely have to build it in the car, not out.
Old 04-09-2012, 09:29 PM
toad559's Avatar
0/11 sssss1508
when building a wall my imo, jus build it as big as you can to your disrire leg room or points of the cars interior. cus a desig is different, no ons gonn likely have the exact deminsion of the cab. if you are crafty with toold andhave some good knowlegde on box building. build it with a max deminsion of which ever cf you want and work with sub/port placemnt, then if you can room in width nd hieght, make it posible for a interchangable port. try to keep one side of the port running next with a side of the wall. if it angles, angle the port also.
Old 04-09-2012, 09:34 PM
0/11 sssss1364
Feedback Score: 25 reviews
i have been waiting on jt buck to get back to me after he told me to email him on what i wanted. its a simple design too would think he would get it done in 5 or so mins lol
97 civic ex new build coming soon. head unit poineer premier 80prs fronts/rears diamond audio hex pros mid & high stage amp Diamond Audio HEX 700.4 sub amp diamond audio d6 1500.1 coming sub stage 1 diamond audio d9 15d2 lwire stinger zero gauge & 4 gauge 1 c&d 102ah batts, kenitik 800,200 amp alt mechman
Old 04-09-2012, 09:37 PM
toad559's Avatar
0/11 sssss1508
heres a example of my wall. which i was able to construct it into a box and shove it in my truck. while i had to take both seats, steering wheel and rearview mirror out. i pulled my max deminsions and subtracted half a inch in the height to compensate the tilt when installing it in. it fits perfect. but in your accord, depending on how you want to build the wall and if your willing to sacrifice the interior and jus puzzle wood pieces and fiberglass n matt it. you probably gotta build the wall inside the car to get the cf you need for 4 12s though. building a wall in a small car, isnt so esy as it looks.
Old 04-09-2012, 10:56 PM
0/11 ssssss378
Thanks for the feed back i think im just gonna try using 2 18'sam im a total noob i dont know shit about cf dimensions none of it lol!!! I took measurements like height width depth thougt i could get a design for a wall i see it takes more than just that!!! Lol!!!
Need help with a design for a box/wall for 6 t1's ENVI3D ONE Enclosure Discussion & Design Construction Help 3 11-20-2011 03:04 PM
Box request for xmikedxl design for wall xmikedxl Box Requests 5 05-30-2011 06:07 PM
FS: 1994-1997 Accord DC POWER 250xp alternator Alex K Wiring, Electrical & Other Installation Equipment 20 01-23-2011 04:22 PM
Box request for jdmferio13 (wall design) jdmferio13 Box Requests 1 12-01-2010 04:39 PM
Need Help With A Trunk Wall/Box Design. partyboy6686 Enclosure Discussion & Design Construction Help 2 09-26-2010 10:47 PM
