How can I make an aero work for this? - Car Audio Classifieds!
Old 04-07-2012, 06:28 PM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
Default How can I make an aero work for this?
So I've been playing around a lot with Torres' calc and had bought some aero's to use for this build. For the life of me though I can't seem to get the right port area to work for this. I'm building for a DC M2 Level 4 15" to be run on either a SAZ1500 or DC 1.2K, either at .5 ohm so the power difference shouldn't be too much. I have 36"Wx16"Hx up to 30" deep though I'd like to keep it around 20"d.
I'm trying to tune to ~30hz (I like my lows) but it seems I can only get the proper tuning/port area with a slot port.
I've never designed my own enclosure so I'm really new to it...any help in getting an aero to work for this is greatly appreciated!
Oh, and I can only have 8" external if I need to...
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
Old 04-07-2012, 06:58 PM
0/11 ssssss189
how are you doing placement? subs and port up or what?
Amps=Crescendo BC5500(subs) C1600.2(mids) & Autotek MM1600.2(tweets) Subs=2 HDC312s Mids/Highs=Crescendo MP8s and 6.5s, AQ PA 6.5s & Supertweeters Electrical=220 amp EA alternator,3 BT100 batteries in the bank & about 75 feet of 0gauge KNU wire...
Old 04-07-2012, 06:59 PM
jhg33k's Avatar
0/11 sssss1531
both will be firing forward into the cabin and sealed off
Old 04-07-2012, 07:00 PM
thekernal123's Avatar
0/11 sssss1813
Try a 6 it should be like 9 per cube if u have a 3 cube box
98 blazer dc 320amp alt 1xs d3100 a 2 type r 15 d4 at 1 ohms on a AQ 3500 doing a 148.5 at 41htz so farrr gotta do some adjustments
Old 04-07-2012, 07:02 PM
jhg33k's Avatar
0/11 sssss1531
I have a 6" but didn't think I had enough port area using it. I wanted to try and stay around 12-16 for port area per foot or does that only apply to slot ports? I have no idea the difference in using an aero vs. a slot so if I can get away with smaller port area per foot then I should be good. But I'm just not sure if I can do that; hence the asking lol
Old 04-07-2012, 07:13 PM
0/11 sssss1813
I believe aeros are from 9-14 but it also depends on hour car and everything
Old 04-07-2012, 07:23 PM
jhg33k's Avatar
0/11 sssss1531
The best I've been able to do with a 6" is around 6 for port area per foot and if I go to an 8" I can get the port/foot right but it's tuned higher than I want...damn this enclosure crap lol!
Old 04-07-2012, 07:39 PM
0/11 ssssss577
what about 2x 4" ports or 3x 3"ports
Old 04-07-2012, 07:44 PM
jhg33k's Avatar
0/11 sssss1531
I've played around with the multiple ports idea but it keeps knocking my tuning freq. up higher than I want. 2 4's give me 5.54 area per cube and 3 3's give me 4.66. I'm guessing it will sound like a train whistle lol. I tried 2 6's and I get slightly over for port area per cube but knocks my tuning into the low 40's
Old 04-07-2012, 07:53 PM
0/11 ssssss577
what feq are you aiming for? and how many cubes <--- i should really read before i post.....
have you though about going square?
HORNS: Can I make these cut big/minis work? Magnet General Car Audio Discussion & Questions 17 03-22-2011 04:46 PM
Who can make one of these for me? :) nismos14 General Car Audio Discussion & Questions 3 02-03-2011 10:16 AM
Does anyone make.... Ryan1126 General Car Audio Discussion & Questions 23 06-02-2010 05:00 AM
make sure im doing this right... gjnelson General Car Audio Discussion & Questions 6 04-08-2009 01:52 AM
How To: Tutorial on how to make Aero-Ports splvictim20 Tutorials & Quick References 4 11-03-2008 01:49 AM
