NEEDZ help w/ goofy box recycle... - Car Audio Classifieds!
Old 04-09-2012, 10:01 PM
O.G. D-Wet's Avatar
0/11 ssssss732
Default NEEDZ help w/ goofy box recycle...
Idk how to figure out the volume of my box with these dimensions... (wedge box) 17-5/8"W x 12-1/4"H x 7-7/16"D1 x 5-3/4"D2
Hey my bro has a goofy little wedge box his friend gave him that housed a seized 10" shallowmount Sony Xplod... We are doing an extremely budget build in his CRX and I decided to adapt my Apex Jr. Super 8 to the prefab wedge box...
So far, I removed the sub and terminals, added a double layer adapter/baffle ontop of the existing baffle with the correct size mounting whole for the 8... I plugged the terminal whole with a 3/4" MDF block... (sub will be inverted)
But now I am considering removing the block and adding a round port... So I need to figure out the dimensions of the box so that I can figure out how to tune the port... if it's even worth doing.
I know this sounds super ghetto but it's a fun little project for my bro and I and it's helping him get excited about his car stereo system. Can someone run those dimensions real quick for me? Any and all advice/criticism is welcome. I know this is a lame install but I'm having lots of fun bonding w my brother with this so please try to keep the comments somewhat helpful lol
"I don't have any clue what alma gates are..." -Cort3232
Old 04-09-2012, 10:06 PM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
What are the dimensions? Could probably plug it into Torres to find out since it has depth 1 and depth 2. Could try it for ya and see what happens at least lol. Would need height, width, bottom depth and top depth.
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
Old 04-09-2012, 10:08 PM
O.G. D-Wet's Avatar
0/11 ssssss732
Old 04-09-2012, 10:11 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
its around half a cube. wouldnt bother with a port. at the price of the port, u could make a new box with AC ply
-Youtube Channel
Old 04-09-2012, 10:12 PM
jhg33k's Avatar
0/11 sssss1531
Old 04-09-2012, 10:17 PM
O.G. D-Wet's Avatar
0/11 ssssss732
Thanks! .6 is what I got in my head too.... I was just hoping it would be a little more... I read about Super 8s liking .75 cubes to 8.3ish cubes :/ I guess I should keep it sealed?
Old 04-09-2012, 10:18 PM
First, find the average depth measurement:
7.44 + 5.75/2 = 6.6"
Converting the rest to decimal (because it's easier on my brain, lol)
W = 17.6
H = 12.25
and the average D from above =6.6
Multiply all of that together = 1423
Divide by 1728 = 0.82 ft^3
I rounded up or down a small amount. If those are outside dimensions, you need to subtract the thickness of the material to determine the inside dimensions. T tune to 40hz using a 3" diameter round port, the length would be about 12.5" long.
Edit: too late, lol
Old 04-09-2012, 10:21 PM
jhg33k's Avatar
0/11 sssss1531
W = 17.6
H = 12.25
Edit: too late, lol.
I need to learn this instead of just plugging numbers into a calculator lol...Math is by far greater than me! Was never one of my strong points and I'll be the first to admit it
Old 04-09-2012, 10:43 PM
O.G. D-Wet's Avatar
0/11 ssssss732
lol thanks guys! so should I play it safe with sealed or try and port the enclosure? I am not sure how my modifications affected the dimensions of the box (terminal removal+inverted sub+ additional double baffle with a 7.25" cutout) lol really have to squeeze every ounce I can!
Old 04-10-2012, 12:49 AM
I would probably keep it sealed. If you want to port it, You can try a small port that's 12-15 inches long and run it along the length of the box, exiting the side. That should put you in the 38-45hz tuning range.
I needz help $5 Paypal 3rdshiftdiscretion Enclosure Discussion & Design Construction Help 8 02-15-2012 09:53 PM
Goofy static/noise problem Ronmeister General Car Audio Discussion & Questions 3 07-07-2011 04:07 PM
Post Cool, goofy, or unique looking subs.. Novicaine General Home Audio/Video 106 10-22-2010 08:00 PM
Recycle your batteries! SPL Guru Off Topic Chat 14 10-08-2008 01:55 PM
