4th order, 6th, Ported sealed??? - Car Audio Classifieds!
Old 04-10-2012, 10:29 AM
0/11 ssssss640
Default 4th order, 6th, Ported sealed???
I have a 04 Lincoln Navigator looking to put in 8 to 12 18s whatever i can fit! I will be building up to the b pillar what would b the best box? what do u thing i can best fit? height 45" width 49" distance 63". I dont mind reconing to 15s if need b! Looking to do the most with space available!!
Old 04-10-2012, 10:59 AM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Maybe you could do 8 18s in a 4th or 6th. Or 10 ported someway. Wouldn't really have much room for amps batteries and such. where in ga are you?
Old 04-10-2012, 11:20 AM
0/11 ssssss640
Columbus, i left a little room for amps batts will go under truck
Old 04-10-2012, 11:22 AM
0/11 sssss6030
I think if you could fit it, 10 in a clam would be awesome. 5 on top 5 on the bottom. What subs are you looking at?
Old 04-10-2012, 11:26 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
Id do 8 in a 4th.
-Youtube Channel
Old 04-10-2012, 12:36 PM
0/11 ssssss640
thats what im leaning towards 8 in a 4th order diamond
Old 04-10-2012, 12:40 PM
duff_thrust's Avatar
0/11 ssssss629
I'd also agree with 8 in a 4th order, but 15's instead of 18's. All up to you though. More possible space available with 15's and it can be a little more efficient that way. In theory more output.
Old 04-10-2012, 12:46 PM
0/11 ssssss640
if i the magic # is 8 i would go with the 18s for cone area! my main question being which box? i had a 6 15 ported doing a 55.8 behind the c so i definitely want to b 3 to 4 db louder behind the b pillar
Old 04-10-2012, 01:00 PM
1loudyukonxl's Avatar
0/11 sssss1569
8 18s in 4th order 20 sealed 40 ported
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
Old 04-10-2012, 01:03 PM
0/11 sssss1569
if built right with 10k it should do 158s 159s
Single 15" 4th Order Bandpass Questions...1.5ft^3 sealed&3.5ft^3 ported? Jdubs04ss Enclosure Discussion & Design Construction Help 14 03-10-2012 11:40 AM
Ported vs 4th vs 6th order bandpass sdelthon General Car Audio Discussion & Questions 20 10-19-2009 03:05 PM
[BASIC] Sealed vs Ported vs Bandpass (4th order) danteBirosel Tutorials & Quick References 0 11-12-2008 01:47 PM
