Need help determining the length of my aer ports for three sundown zv3 15"s. - Car Audio Classifieds!
Old 04-15-2012, 03:03 PM
0/11 sssss1785
Default Need help determining the length of my aer ports for three sundown zv3 15"s.
Hello everybody noob on board here, I'm having a enclourse built Tommorow fr three sundown zv3 15"s in 9.83 cubes net after displacements. The subs will be in a triangle formation almost . I want to tune to about 34hz and I want to use two 8" aero ports.. I need to no wat length to cut the aero tube to and how long will it be from flare to flare total length. If needed my box external dimensions are 41.5w. 21.5h. 28.5l ,, any help will be much appreciated.
Old 04-15-2012, 03:44 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Products Menu
Looks like about 19" each. Now, that's total length from flare to flare. The flares themselves are 5", so your actual tube cut will be 14"
[Edit: I am not 100% if the 8" flares are 5", so you'll have to measure. But the total port length including flares is 19" for 34hz]
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 04-15-2012, 03:47 PM
0/11 sssss1480
Feedback Score: 63 reviews
With those dimension, assuming you use 3/4" wood. I got 12.5 cubes gross. So 2 8" aeros which are actually 7.875" at 34hz, need to be 13" long each
Old 04-15-2012, 03:50 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Did you account for sub displacement? Ports? 45's? Bracing? Double or triple baffle? The guy said "9.83 cubes net after displacement" not "I think it's about 10 cubes."
4x world champ
- Floyd E. Toole
Crazy4bass (04-15-2012)
Old 04-15-2012, 03:57 PM
0/11 sssss1480
No sorry. The calculator I use, uses gross volume. I know some people don't like it. But it's what I'm use to and it works for me. We arrived close. Mine might actually come to 35 or 36 hz. Lol
Old 04-15-2012, 04:21 PM
0/11 sssss1785
Hey thanks for the reply, yea we accounted for bracing, sub displacements, and port and got 9.83 cubes net. I'm going to try those metal aero ports that psychoacoustics make. I can't get ahold to Derrick on here so I'm try his. I'm not sure wat the flares are.
Old 04-15-2012, 04:36 PM
0/11 sssss1480
Yeah, Derrick can get bad at replying. If you really want them though just be patient he will make them
Old 04-15-2012, 04:55 PM
0/11 sssss1785
Yea I figure he is a very busy guy, so I'm probaly going to try psychoacoustics metal aero ports, they seem a lot stronger.
Sundown Zv3 15" metering *VID* Skip01 (Sundown Audio) 58 03-27-2012 10:31 AM
Sundown Zv3 15" D2 *Clean* Winter_C 15" Subwoofers 46 02-27-2012 05:17 PM
15" sub giveaway thoughts...and Sundown Zv3 15" EXCURSIONNNNNNN Skip01 Car Audio Videos 12 12-22-2011 05:58 PM
How do you calculate length of center slot ports? taylorpro Enclosure Discussion & Design Construction Help 9 03-08-2011 04:08 AM
Calculating length for multiple tube ports white4d96 Enclosure Discussion & Design Construction Help 0 03-03-2010 07:58 PM
