How close can a aero port be to a woofer without harming the sound. - Car Audio Classifieds!
Old 04-16-2012, 07:03 PM
0/11 sssss1785
Default How close can a aero port be to a woofer without harming the sound.
How close can a aero port be to a woofer without harming the sound.,, im running two 8"ports on three sundown zv3 15"s in 9.83 cubes , my two aer are 18.5"s and ten inches from the back wall. So I no I'm good there, but I worried about wat if the sub is within 2 to 5 inches of the aero? Will this hurt my sound or wind turbulence.
Old 04-16-2012, 07:10 PM
0/11 ssssss543
Is the woofers firing up and the ports below them firing back? Regardless think of the enclosure of one big pressure chamber, the port will tune it fairly well regardless of location. Where we run into issues is extremely large slot ports right beside a woofer. Longer circular ports will not create as much of a problem.
Bought from - Hazardous0388 (4 db Drive 2000.1s), Psychoacoustics (4 Powerbass XA 3000'ds), and blackedoutavy (PPI A200)
Sold to - D-Rew (Knu 1/0), d77543020 (Knu 1/0), F1McLarenAGR (Audioque 4x90), and SacTownBully84 (Knu 1/0)
Traded with - SacTownBully84 (my xa3kd for his xa1.5kd + cash)
Old 04-16-2012, 07:31 PM
0/11 sssss1785
Yes subs up port back and the ports are not quite under them, the ports stop about three inches before u can get Get to them but the subs will still be above the port
Old 04-16-2012, 10:45 PM
0/11 ssssss543
So we are then talking about a few inches from the motor which is even further than the cone, I have 6" precision ports about 10" below my hdc3's and its hella loud, I think you'll be fine.
How close can a port end be to a wall? laextreme5 Enclosure Discussion & Design Construction Help 7 02-26-2012 01:07 PM
aero port box for 4 sa-8's, too much port? Dbmonster (Sundown Audio) 4 08-11-2011 03:08 AM
finding 10" aero port, port calculation help darkkon General Car Audio Discussion & Questions 6 07-24-2011 08:26 PM
~143^2 Aero Port vs 235^2 Slot Port for 21 net cube enclosure VOPA1 Enclosure Discussion & Design Construction Help 6 12-02-2010 05:03 PM
