So confused on this aero port length tuning, need guidance bad. - Car Audio Classifieds!
Old 04-17-2012, 04:53 PM
0/11 sssss1785
Default So confused on this aero port length tuning, need guidance bad.
Ok listen everybody, this is my first time using aeros, I'm buying two 8" kits from Derrick on here and I need to no wat to cut the tube to. My box is 9.83 cubic ft net after displacements for three zv3 15s, Subs up port back. I want to tune to 34.8hz. Psp calculator tells me it needs to be 17.9 with flares , but here's wat I confused about it, is that 17.9"s from flare to flare meaning if I took a measuring tape and measured from flare to flare it would say 17.9 or is that from the bottom of the outer flare to the bottom of the inner flare. Pictures would be nice if anybody has some showing me wat psp is measuring from.
Old 04-17-2012, 04:55 PM
tacomaguy1's Avatar
0/11 sssss4401
the total length from end to end with the flares on
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 04-17-2012, 04:56 PM
Slaughterhouse's Avatar
0/11 ssssss868
correct. and when you enter the airspace make sure it's with all displacements even the port.
* TC Sounds, Arc Audio, Hybrid Audio, Sundown Audio, Brax Audio, Helix Audio, Sony XM, Focal, Morel, Hertz *
Old 04-17-2012, 05:24 PM
0/11 sssss1785
Ok so if I need 17.9 total, let's say the front and back flares are 5"s tall each so that's ten inches total so the tube will be 7.9 inches rite
Old 04-17-2012, 05:38 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
yes
-Youtube Channel
Old 04-17-2012, 06:09 PM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
Passing this along as I've had to use it as well....
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
The Following User Says Thank You to jhg33k For This Useful Post:
150orbetter (04-19-2012)
Old 04-19-2012, 11:24 PM
0/11 ssssss767
so many people do not under stand this just by explaining, this is an awesome example.
Port Length vs. Physical Port Length nicholask1993 Enclosure Discussion & Design Construction Help 28 10-21-2011 04:01 PM
box tuning insane port length Russellabt Enclosure Discussion & Design Construction Help 15 10-09-2011 03:02 PM
Aero port tuning help with 90 Degree sweeps BassHead143 General Car Audio Discussion & Questions 5 07-04-2011 02:06 AM
Box tuning and port length gclark84 Enclosure Discussion & Design Construction Help 1 01-24-2010 11:38 AM
Aero port tuning tater Enclosure Discussion & Design Construction Help 2 05-26-2009 01:55 AM
