reason for 45 angle in box - Car Audio Classifieds!
Old 04-17-2012, 08:22 PM
0/11 sssss1364
Feedback Score: 25 reviews
Default reason for 45 angle in box
just like the title says does it make it better for sq route or what. im going for sql in my system and had a design made and thought it would have 45s in port and in box but it doesnt, does that mean it will not be as musical as one with them?
97 civic ex new build coming soon. head unit poineer premier 80prs fronts/rears diamond audio hex pros mid & high stage amp Diamond Audio HEX 700.4 sub amp diamond audio d6 1500.1 coming sub stage 1 diamond audio d9 15d2 lwire stinger zero gauge & 4 gauge 1 c&d 102ah batts, kenitik 800,200 amp alt mechman
Old 04-17-2012, 08:31 PM
Matt3824's Avatar
0/11 sssss3754
45s make the box stronger and makes them unload better
0/11 sssss1364
unloading meaning?.... lol
Old 04-17-2012, 08:34 PM
Me > Lord Van
0/11 sssss2831
It helps direct air through the port and reduces "pressure spots" inside the box which can reduce output and potentially damage subs.
Team DOA
10 inches of terror
One DD 9510F + one kicker zx2500=150+ db
One Sundown SA-8 + 2 mb quart 2000's = 150+ db
-2006, 2007, 2009, and 2010 MECA World Champion
-2008 Bassrace 130-139.9 National Champion
Old 04-17-2012, 08:37 PM
Wes669's Avatar
Street light banger
0/11 sssss1869
Stability and movement of air flow
Old 04-17-2012, 08:40 PM
0/11 sssss1364
so i should have it if i plan on doing 3k? lol i feel the answer is yes
badmofo529's Avatar
0/11 sssss3329
45's dont always help
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
The Following User Says Thank You to badmofo529 For This Useful Post:
ascitiesburn69 (04-17-2012)
Old 04-17-2012, 08:42 PM
ascitiesburn69's Avatar
0/11 sssss1645
This.
Team S.P.E.A.D.
Trunks FTW
Old 04-17-2012, 08:43 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
This. Ontop of adding support to the 4 panels theyre connecting.
They wont always make things 'louder' but I like to use them for the structural addition and to smooth would-be dramatic bends to the port(s) etc etc
Louder. Lower.
Team Tupperware
Old 04-17-2012, 08:44 PM
0/11 sssss1364
i had jt buck do it and i know he knows what hes doing but just wanted to make sure, i thought 45s made it more musical
FS: Small Right Angle Brackets - $10 per lb sundownz Miscellaneous Stuff For Sale 28 04-17-2012 03:56 PM
Need someone to cut me some wood at 45 degree angle mendezm9 Wanting to Buy (WTB) 1 06-22-2011 02:02 AM
How do calculate this angle/length? FatBoy2 Enclosure Discussion & Design Construction Help 13 09-09-2010 04:27 PM
Wide Angle/Macro Lens on the Kodak Zi8 twistedchild420 Off Topic Chat 0 06-21-2010 10:37 PM
