Aero Port Help! - Car Audio Classifieds!
Old 04-18-2012, 05:06 PM
0/11 ssssss639
Default Aero Port Help!
I am trying to put something together for a DC lvl 3 15", and I have never played with Aero's before. The goal here is more geared towards SPL. So my question is
-How much port is required with aero's? I have read between 8-13 is appropriate. I would like to stick to the upper end of that.
Between trying different setups in torres, I have found that if i use a single 8", i don't really have enough room unless half the port is in the box and half is out. What i have come up with is as follows:
14x28x22
Three 4" aeros at 20" a piece. (i couldn't get acceptable numbers with any number of 6"s)
3.25 cu ft net after displacement.
Can someone help me out?
Old 04-18-2012, 05:23 PM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
wooooooah.... no hang on a sec
you probably wont like me
Old 04-18-2012, 05:24 PM
upzaw2000's Avatar
0/11 ssss14427
use PSP-inc.com go to tools and use the calculator.... 1 6inch or 2 4 inch ports is more than enough for that sub
Old 04-18-2012, 05:31 PM
upzaw2000's Avatar
0/11 ssss14427
make box bigger to drop tuning more.
Old 04-18-2012, 05:32 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
but remember that psp calculates the tuning assuming you use external aeros. If you plan on using the aeros inside of the box calculate for the displacement of the aeros.
Old 04-18-2012, 05:51 PM
cmobley's Avatar
0/11 ssssss568
1 8" aero works great for a single 15" sub.
2005 Dodge Magnum- Retired
2010 Camaro RS-24" rims/mini-system
1972 Buick Skylark-26"/24" rims/4th order through deck
2012 Harley Streetglide- Under construction👍
2011 MECA Street 2 Finals 2nd Place
2011 MECA Street 2 National Points Champ
Old 04-18-2012, 06:38 PM
0/11 ssssss639
My max size is 36x20x14. And that leaves no room for external port. With the 4"s they would be internal and torres calculates that.
Can anyone take those dims and do a basic design ideally above 30 hz?
Sent from my DROIDX using Tapatalk
Old 04-18-2012, 06:40 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Torres does not account for flared ports.
Old 04-18-2012, 09:21 PM
0/11 ssssss639
alright. well that small amount of change i can account for and use PSP'd calc. But what is the absolute most port per sq ft i should use?
Old 04-19-2012, 02:46 PM
0/11 ssssss639
self bamp
aero port box for 4 sa-8's, too much port? Dbmonster (Sundown Audio) 4 08-11-2011 03:08 AM
finding 10" aero port, port calculation help darkkon General Car Audio Discussion & Questions 6 07-24-2011 08:26 PM
aero-port vs. slot port? thumper21 General Car Audio Discussion & Questions 23 03-22-2011 12:12 PM
~143^2 Aero Port vs 235^2 Slot Port for 21 net cube enclosure VOPA1 Enclosure Discussion & Design Construction Help 6 12-02-2010 05:03 PM
