4 12" Cerwin Vegas in a 97 Chevy Blazer 4 door questions. - Car Audio Classifieds!
Old 04-18-2012, 06:47 PM
0/11 sssssss15
Question 4 12" Cerwin Vegas in a 97 Chevy Blazer 4 door questions.
Ok here is my list of questions.I have a 97 Blazer and i have 4 12" CVs. What would be the loudest way to go?. Will a ported box be better than a 4th order bandpass? I still havent decided which route to go on amps. The subs are 500 rms and 1000 max. They are daul 2ohn v/c. So to power these good i would need 1 good amp that goes down to .05ohm or 2 good 1 ohm amps. I was thinking the Crescendo 3500. What would you guys do?
Old 04-18-2012, 07:10 PM
twentyhurtz's Avatar
0/11 sssss1335
I have had two friends both run 4 door blazers, both did subs up port back, one did an aq 3500.1 on 3 sa-15's but the box didn't have enough port area, did about a 148. The other actually used 2 of those same sa-15's and an orion 2500 with a similar setup and got a 152.5 out of it.
Since your subs are dual 2ohm i would get 1 big 1ohm stable amp that you can burp at .25 and run at 1ohm daily. - if you do competitions. Are you trying to build a wall? bandpass may be hard to fit back there in a "no wall" application.
Old 04-18-2012, 07:39 PM
0/11 sssssss15
Thats what im trying to figure out. From what the specs say, the subs need 1.7 per sub. I dont need my rear seats so that dose not matter. Im not trying to compete just want to get as loud as i can,lol.Would i need more power or less with that kind of setup?
0/11 ssssss215
Do a ported box it will be tough to make a band pass louder unless you have done them before.
Old 04-18-2012, 07:40 PM
0/11 sssssss15
Would a wall be overkill for 4 12s?lol.
Old 04-18-2012, 07:50 PM
0/11 sssss1335
Can you clarify?
Old 04-18-2012, 07:59 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Originally Posted by twentyhurtz View Post
Can you clarify?
im sure he means 1.7 cubes. Also 4 D2 subs cant wire to .5 ohm, either 1 ohm or .25 ohm.
The Following User Says Thank You to Crazy4bass For This Useful Post:
vj226966 (04-19-2012)
Old 04-19-2012, 06:30 AM
0/11 sssssss15
Can you clarify?
Cubes.
Blazer door panels + 10" mids????? EpicenterDesigns Miscellaneous Build Logs 55 12-12-2010 11:44 AM
Re-building 2x 18" Old School Cerwin Vegas Lord Baccus Miscellaneous Build Logs 1 12-03-2010 10:16 AM
wtb: 1998 chevy blazer 4 door front door panels bgaccord Wanting to Buy (WTB) 0 08-23-2010 11:02 PM
2 12" Cerwin Vega Vegas BNIB 77 LJ turbo 12" Subwoofers 3 05-08-2010 08:51 AM
chevy blazer 4 door tuning? and other questions Hirschblazin General Car Audio Discussion & Questions 3 06-21-2009 07:45 PM
