underseat box build input needed - Car Audio Classifieds!
Old 04-18-2012, 09:47 PM
green monster's Avatar
0/11 ssssss147
Default underseat box build input needed
Ok so i am in the process of building an underseat box for 4 sa8's for my crew cab and would like some input. So far i have the front, back, and sides temporarily assembed to check gross volume before i start glassing the bottom and am right at 3 cubes. Am i good there? Can only go smaller as i am at my max dimensions. Second question. Is one 4 inch aero enough and what would be the best placement ? Driver side, pass side, and front are my options
Old 04-18-2012, 10:11 PM
Matt3824's Avatar
0/11 sssss3754
3 cubes is fine, port on pass side
Need input on sa12 box before I build it k3n12ock (Sundown Audio) 17 01-25-2013 05:33 PM
dodge underseat 4 e8s build log? mwerling1212 General Car Audio Discussion & Questions 1 06-27-2011 02:22 PM
Box input on upcoming build grimreper912003 General Car Audio Discussion & Questions 38 10-25-2009 09:22 AM
Moped Build *input needed* aturcotte127317 Miscellaneous Build Logs 31 07-20-2009 03:41 PM
Box build help needed on1wheel01 Enclosure Discussion & Design Construction Help 12 03-08-2009 12:40 AM
