What type of enclosure is this? - Car Audio Classifieds!
Old 04-19-2012, 10:41 PM
0/11 sssss1330
Default What type of enclosure is this?
I have messed with 6th orders before with great success, but I am currently using a ported box. The subs are unloading on the low notes due to port placement and I was considering trying something like this. What type of enclosure would this be and would it be successful?
It's like a series tuned 6th order, but instead of the subs firing into the front chamber they are firing into the cabin of the vehicle.
2010 Volkswagen CC
HRE Wheels | Nitto Tires | Solo-Werks
Ground Zero | Ampere Audio | Juicebox Battery | AudioControl | KnuKonceptz
Old 04-19-2012, 10:49 PM
0/11 ssssss288
A buddy of mine wanted me to build him a box that looked like this "cause it looked cool" and it was the worst sounding box ever. It seamed like the pressure didnt build up enough between the ports to produce a punchy enough sound. Very muffled
TEAM D.O.A.
Old 04-19-2012, 10:56 PM
mega fatty
0/11 sssss6008
this would be a dual chamber reflex, if the section with the sub is 2x bigger then the other one, and all 3 ports are the same
they work well when build properly
07 mazdaspeed3
rd d9 @ .5ohm
Old 04-19-2012, 10:59 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
I can't see the first pic, but that last pic is known as an "ABC" box, isn't it? Aperiodic Bi Chamber?
I built one of those a while back. It does work. 1/3, 2/3 with (3) equal length ports tunes up one octave.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 04-19-2012, 11:13 PM
0/11 ssssss767
this is true it is an abc but to be more specific the chamber with the sub is the 2/3rd chamber and all 3 ports must have equal port area as well as equal port length
Old 04-20-2012, 12:39 AM
0/11 sssss1330
How much port area per cube for an ABC box? I'm willing to try it
2010 Volkswagen CC
Old 04-20-2012, 09:22 AM
0/11 ssssss767
build the front chamber to the air space that the sub calls for on the spec sheet use a port that is between 8 and 12.5 per cube and tune low about 25-35hz the smaller or higher tuned chamber will be almost 2xs higher than the larger chamber (for example 30 in front will be 57hz in the rear) the result if done properly should be a box with great low end out put and still have the ability to play higher and have good musicality. if you use higher tunings it has the ability to be a good spl enclosure as well.
Old 04-20-2012, 09:49 AM
TEAM 6HZ UNDER
0/11 sssss2020
what does an abc enclosure sacrifice? most boxes sacrifice something like high end output, efficiency, etc. what about this box?
1998 Grand Cherokee 5.9 - Sony HU, Stock Infinity Mids/Highs (for now), OA18 v2, AP mini 1500 (fight me)
We all on here were newbs at one point in our life thats what alot of ppl seem to forget its about the love of bass at the end of the day
Old 04-20-2012, 10:09 AM
AudioPsiho's Avatar
psihič
0/11 ssssss560
and i think the sub should be inside the box bettwen the chambers (magnet facinf into bigger one)
Old 04-21-2012, 08:25 AM
0/11 ssssss767
this is correct it has been a while since i have built one so i overlooked this good catch. it is the same as a 7th order except it has the port conecting the 2 chambers whereas the 7th doesn't, that is what makes it also considered an 8th order.
Cheap Alpine Type R's? or Type X's? law112493 Wanting to Buy (WTB) 24 10-03-2011 09:23 PM
Enclosure Request - Jaguar X-Type WesSide Off Topic Chat 0 06-05-2010 04:31 PM
4 Alpine Type E 12s for a Type R 15? jakobkay Bargain Bin 13 06-01-2010 11:13 PM
Enclosure Build: maintrain's home enclosure Pioneer~Saturn Build Logs 80 01-19-2010 05:32 PM
Type R Enclosure Question strpperpolef150 Enclosure Discussion & Design Construction Help 0 07-23-2009 01:21 PM
