port size? - Car Audio Classifieds!
Old 04-20-2012, 09:06 PM
art1618's Avatar
CACO SUPPORTER
0/11 sssss3165
Default port size?
i have two 12" rival M.E.s
i have 6 cubes available before sub and port displacement. what should my port dimensions be? listen to hiphop alot and rock if that helps.
Dual 4'' black anodized flat-wound voice coil
57.5mm winding length
10''x 3 damper
High rubber surround
Non-pressed paper woven cone
Electro (black) T-yolk
PP (woven)dust cap
2+2 Ohm Resistance
100oz x 3 (220mm×110mm×20mm) magnet
2000 watts RMS
G.W: 52lbs
Parameters:
Qes 0.596
Qms 2.625
Qts 0.486
Fs 35.66 Hz
Vas 1.308 ft^3
Mms 193.9 g
BL 17.14 Tm
Le 1.57 mH
Re 4.033 ohm
Sd 78.14 in^2
Xmax 27mm (one way)
SPL 86.53 dB
Old 04-20-2012, 09:35 PM
art1618's Avatar
CACO SUPPORTER
0/11 sssss3165
help pleeze?
Old 04-21-2012, 11:23 AM
art1618's Avatar
CACO SUPPORTER
0/11 sssss3165
anyone? lol
Old 04-21-2012, 11:29 AM
0/11 ssssss892
there are a few sites even mfg sites that have box spec's and programs the12volt.com is one please support your local shop or box builder spread some $$$ what most people ask for is what people do or use to do for a living? car audio is becoming a lost Art many don't even know how to build anymore or it's not worth there time to reply.
Old 04-21-2012, 11:36 AM
art1618's Avatar
CACO SUPPORTER
0/11 sssss3165
well, im having the box built at a local shop, i just needed some port dims so he can build it, they usually deal with mainstream brands. i dont really get the tuning part, hence the post.
Old 04-21-2012, 11:44 AM
0/11 ssssss892
if you are at a shop and they don't know how to tune a box i would RUN AWAY !!!!! Basic 123 in box building.
The Following User Says Thank You to Crunk For This Useful Post:
SacTownBully84 (05-07-2012)
Old 04-21-2012, 11:46 AM
art1618's Avatar
CACO SUPPORTER
0/11 sssss3165
i just dont want it to come back with a vent inappropriate to the subs. thats all really.
Old 04-21-2012, 11:48 AM
zombie killer
0/11 ssssss290
what size amp will you be using
Old 04-21-2012, 11:50 AM
art1618's Avatar
CACO SUPPORTER
0/11 sssss3165
2- 2k amps one for each sub.
Old 04-21-2012, 11:54 AM
zombie killer
0/11 ssssss290
whats the width and the height of the box
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Aero port size Morals Enclosure Discussion & Design Construction Help 11 04-08-2012 02:23 AM
Port Size? Radioactiv Enclosure Discussion & Design Construction Help 2 11-10-2010 06:21 PM
Need help with port size nastyone Enclosure Discussion & Design Construction Help 2 02-20-2010 12:45 PM
Box and Port size RD HW 18 Drock040687 General Car Audio Discussion & Questions 44 11-28-2009 07:12 PM
Port Size BassikInstincts Enclosure Discussion & Design Construction Help 10 03-30-2009 08:19 AM
