how to i add port volume? - Car Audio Classifieds!
Old 04-21-2012, 12:53 AM
0/11 ssssss340
Default how to i add port volume?
when adding port volume to a slotted port box, do i add the volume of the airspace, AND the material used to make the port? or just the material required to make the port? thanks!
Old 04-21-2012, 01:14 AM
ascitiesburn69's Avatar
0/11 sssss1645
Team S.P.E.A.D.
Trunks FTW
Old 04-22-2012, 12:22 AM
0/11 ssssss340
what?
Old 04-22-2012, 12:27 AM
0/11 ssssss249
I think he is trying to figure out how much area his port will take away from the enclosure volume.
Old 04-22-2012, 12:36 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
heres a good way to do it. If the port uses 1 wall then you change your LxH to L+1.5xH+.75 (if the L is parallel to the wall being used, if H is parallel then add 1.5 to H) If it uses two walls of the box then L+.75xH+.75 to give you total volume taken up by the port. If three walls then only add .75 to the L or H depending on which applies.
But yes. You include the material (wall thickness) of the port.
Current Build:
#60sHereIcome
Old 04-22-2012, 03:45 AM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
If you mean how much box volume the port takes up, the air inside the port is also counted.
Old 04-22-2012, 10:37 AM
0/11 ssssss340
this! thankyou!
Old 04-22-2012, 10:41 AM
0/11 sssssss10
how many common walls do you want?
Best Air Volume/Tuning/Port for 18" TC 5200 Jdubs04ss General Car Audio Discussion & Questions 5 11-01-2011 06:26 PM
do i include port volume in my box vloume... bikerdc17 Enclosure Discussion & Design Construction Help 3 05-17-2011 01:21 PM
Best way to add volume to box MR_MT Enclosure Discussion & Design Construction Help 14 11-29-2010 08:37 PM
question on port volume on kicker cvt 10's mineralgrey01gt General Car Audio Discussion & Questions 3 10-02-2010 02:56 AM
Volume going down by it self? davidrforbus General Car Audio Discussion & Questions 21 06-02-2010 03:14 PM
