Hd3 18 In the hatch Need help with box!! - Car Audio Classifieds!
Old 04-22-2012, 09:13 PM
0/11 ssssssss6
Default Hd3 18 In the hatch Need help with box!!
Box is for a 93' mazda mx-3 hatchback (kinda like a bubble window)
its going to be a hd3 18
MAX dem's i can fit is 30 across 24 back and 20 tall
i want sub and port facing up towards the back glass. i was using the re box calc and only way i can get the tuning down to 32-35 with the sub and port up is with a L port which im not a huge fan open to any suggestions i really want to try to stay in 5-6 cube range with the 18 and the max dem's i mentioned is pushing it now
Old 04-22-2012, 09:54 PM
BASSNUT
0/11 ssssss180
personally i would use the max space you can. also how big are you planning on making your port? are you going off of the general rule of thumb of 16 square inches of port per cubic foot of box volume? also i would personally suggest doing sub up, port back. being that your car is a hatchback you will see a little more db gain. I used to have a single HDC3-18 in my tiburon and that is the box design i found to work best in my hatchback and there was also a noticeable difference in how loud it was and sound quality as well. (Also when i had mine, i tuned it to 32hz and it killed the lows )
team sedatephobia
2 AQ HDC3-10s
DC Audio 3.5kw
143.9DB
Old 04-22-2012, 10:21 PM
0/11 ssssssss6
Yea im cutting it close now tho at 16:1 its about 100-108 in port area with the design ive got its [email protected] 34 hz and after all the disp ill be down to around 5 cubes :/ and im trying to use all the back of the hatch and my only issue with the port back is there isnt but 24 inches of space from the back seat to the back of the car so with a 18 to get it to fit and still have the rear fireing port its cutting it close for space
Old 04-22-2012, 10:48 PM
BASSNUT
0/11 ssssss180
5 cubes will be alright for that sub. I guess port up would work with an L port but how long does the port need to [email protected]? Also how wide is the opening? Im almost thinking you'd be better off doing 14:1 instead of 16:1. There wont be a noticable difference and you'll probably be able to have a shorter port length/narrower opening which may allow you to do sub up port back. (unless you really want to do sub up port up)
team sedatephobia
2 AQ HDC3-10s
DC Audio 3.5kw
143.9DB
Old 04-22-2012, 10:50 PM
0/11 ssssssss6
ummm i want to say 30 in total or a little over @ 4inches wide >.> i checked it with re box calc and another calc and they both gave 30 inches
Old 04-23-2012, 01:34 PM
BASSNUT
0/11 ssssss180
is that length with the width being 4x22.5 or 4x28.5?
team sedatephobia
2 AQ HDC3-10s
DC Audio 3.5kw
143.9DB
Old 04-23-2012, 01:35 PM
BASSNUT
0/11 ssssss180
either way, you shouldn't have an issue with doing an L port.
team sedatephobia
2 AQ HDC3-10s
DC Audio 3.5kw
143.9DB
Old 04-23-2012, 01:51 PM
0/11 ssssssss6
umm i want to say the L port gave 30 and was 4 wide and 22.5 tall then was 15.25 deep and bends for another 8 RE box calc measures the outside wall for port length. i have a picture saved from where i designed a box on re calc if i could figure how to upload it
Old 04-23-2012, 01:53 PM
BASSNUT
0/11 ssssss180
i quickly drew up a box, if you'd like to pm me your email i can send it to you.
team sedatephobia
2 AQ HDC3-10s
DC Audio 3.5kw
143.9DB
0/11 ssssssss6
and the port size/ length isnt a issue on running sub up port back ( what i originally wanted) its the back of the car from the seat back is only 24 inches max after the sub and 1.5in of food ill be pushing close to 20inches then max ill have is a 4 inch gap to the back of the car
What difference does the box being further away from hatch make? jhg33k General Car Audio Discussion & Questions 4 08-23-2011 04:54 PM
12" xl box for a hatch audiobahnfan Enclosure Discussion & Design Construction Help 1 04-14-2011 07:49 PM
New box for my 15" HD3 - question k3n12ock General Car Audio Discussion & Questions 15 07-03-2010 01:51 PM
Box question:AQ HD3 15 k3n12ock Enclosure Discussion & Design Construction Help 40 05-22-2010 12:48 PM
So I'm looking to building a new box for my HD3 k3n12ock General Car Audio Discussion & Questions 4 03-09-2010 03:12 AM
