No output from enclosure. - Car Audio Classifieds!
Old 04-24-2012, 10:47 PM
0/11 sssss1330
Default No output from enclosure.
Okay guys. I'm trying to shoehorn my two Lanzar OPTI1535Ds into my Eagle Talon. Lanzar recommends 2.5 ft^3 tuned to 35, this seemed small to me but the suspension isn't as stiff as most drivers because they use spaced spiders, so I figured anything bigger than 2.5 cubes would be fine.
My max enclosure size in the car is 12.75" H x 32" W x 36" D. That gave me 6.39 cubes before port displacement. The subs are inverted. I figured I would use an 8" Sonotube for a port to keep box volume as high as possible.
Design 1: 6.10 ft^3 at 32 Hz
This did a 145.3 at 41-43 Hz on 1500W before rise, but there was no low end below 33 Hz. I believe the port was unloading so I decided to modify the box.
Design 2: 5.65 ft^3 at 28 Hz
Lowered tuning since I had room for a longer port. This design was pathetic. The subs unloaded HORRIBLE for some reason, even though the box is smaller, and the port barely moved any air.
Anyone have any ideas what I am doing wrong? I have designed boxes before and never had a problem, now I'm at the threshold of wanting to sell everything because these designs should work fine on paper, yet they are miserable.
Sorry for the long winded post.
2010 Volkswagen CC
HRE Wheels | Nitto Tires | Solo-Werks
Ground Zero | Ampere Audio | Juicebox Battery | AudioControl | KnuKonceptz
Old 04-24-2012, 10:58 PM
0/11 sssss1286
slot port on bottom of box width wize then subs directly over the port
Old 04-24-2012, 11:04 PM
Anton Miller's Avatar
DoucheMiller
0/11 sssss3720
subs wired out of phase, your welcome
1997 CHEVY CAVALIER - BUILT FOR EFFICIENCY!! YOUTUBE:
Old 04-24-2012, 11:05 PM
0/11 sssss1943
Do you have any pics of the box in the car?
I had a single 15 in mine in 3.5 cubes and there wasnt much room left back there.
Old 04-24-2012, 11:20 PM
0/11 sssss1330
Only have 12.75" of height available and the subs are 10" deep so that's not an option... Can only invert the subs at the front of the box because the glass is in the way.
I'll go check the phasing
Gave up back seats too.
2010 Volkswagen CC
Old 04-24-2012, 11:28 PM
0/11 sssss1943
Put the subs way closer to the back of the box and push the box back closer to the hatch and move all the junk.
Should be louder with the subs firing off the glass rather than in the middle of the car.
Old 04-24-2012, 11:29 PM
duff_thrust's Avatar
0/11 ssssss629
I have had good luck with subs up port up in a hatch car.
Old 04-24-2012, 11:34 PM
0/11 ssssss629
Also what are your filter settings set at on your amp? Subs out of phase will cancel a bit for sure.
Old 04-24-2012, 11:37 PM
art1618's Avatar
CACO SUPPORTER
0/11 sssss3165
THERES YOUR PROBLEM!!! missing a sub. jk
s'cribed
Old 04-24-2012, 11:40 PM
0/11 sssss1943
Taking the plastic piece off the back of the hatch gives you a little extra height too.
Radio Output 1 Loud Explorer General Car Audio Discussion & Questions 2 10-07-2011 10:43 AM
Clipped Dc Output Rayo187 Sound Quality Area 3 02-13-2011 07:21 PM
dd z1a output? bombout800 General Car Audio Discussion & Questions 2 07-28-2010 03:33 PM
Enclosure Build: maintrain's home enclosure Pioneer~Saturn Build Logs 80 01-19-2010 05:32 PM
How much output would I lose... hornedfrog1985 General Car Audio Discussion & Questions 10 10-20-2009 06:34 PM
