Little help with port length? - Car Audio Classifieds!
Old 04-25-2012, 11:48 AM
0/11 ssssss466
Default Little help with port length?
Ok im building a slot ported box for 2 15s 8 cubes at 30 hz using the 12volt.com. My port is in the center and it says port length is 15.4 inches is that for each wall or do i split it and make each wall 7.7? Thanks
whatheissayingisthatyoursentencestructureandgramma risshitandyouneedtoleantopunctuateandmaybegotothel ibraryandcheckoutanenglishbookormaybestopasecondgr aderonthestreetandaskhimtoteachyouhowtotypeandorge tyourpointacrossinthewrittenwordbecausenobodycanco mprehendanydamnthingyouaretryingtosay
Old 04-25-2012, 03:59 PM
Are you planning to actually run the port in the center? You mention a "wall" so I'm just checking.
The port length is always determined from the center of the port itself, not the panels (or "walls") that make up the port. It's an imaginary line. Assuming the port is straight with no turns, then both sides of the port would be 15.4" long.
Old 04-25-2012, 10:13 PM
0/11 ssssss466
okay thanks
Port Length vs. Physical Port Length nicholask1993 Enclosure Discussion & Design Construction Help 28 10-21-2011 04:01 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 10:52 PM
Port Length realrich159 General Car Audio Discussion & Questions 0 05-19-2011 04:55 PM
port length help dylan9999 General Car Audio Discussion & Questions 8 07-07-2010 03:18 AM
