box build opinions for a 95 nissan maxima - Car Audio Classifieds!
Old 04-26-2012, 11:34 AM
psi
0/11 sssssss26
Default box build opinions for a 95 nissan maxima
for two 15 or 1 psi pf2 fire inside car any help will do ty
Old 04-26-2012, 11:36 AM
Matt3824's Avatar
0/11 sssss3754
Go check out PSI's build log and see what he did. 2 10's in a 4th order, port going through the ski hole.
Old 04-26-2012, 04:53 PM
psi
0/11 sssssss26
i seen that but im not a box designer so i need all the help i can get but that wat i want to to or some thing like that for 1 15
box build opinions for a 2002 nissan maxima acuraboy921 General Car Audio Discussion & Questions 3 03-27-2012 08:07 PM
2002 nissan maxima best trunk set up?? acuraboy921 General Car Audio Discussion & Questions 10 03-27-2012 08:06 PM
GoinDef's 2000 Nissan Maxima Build Log Goindef154 Build Logs 58 03-26-2012 06:16 PM
Nissan maxima A.I. James Cali Sounds 4 04-20-2011 09:06 AM
2003 Nissan Maxima cant_get_ryte General Car Audio Discussion & Questions 14 03-27-2010 09:56 AM
