4 SA-12s in a wall - Car Audio Classifieds!
Old 04-26-2012, 04:27 PM
ChanCon's Avatar
CACO Late Night Crew
0/11 ssssss446
Default 4 SA-12s in a wall
Hey guys I'm laying out a box design for 4 sa-12's in my 99 nissan frontier. I'm wanting to do a wall behind the seats like the one shown. I'm thinking 6.5-7 cubes after displacement and 130 sq. in. of port tuned to 33hz. They'll be ran on a saz3500 . Oh and I'm planning to run the port at the top of the box firing towards the windshield. This will be my first wall build so any specific pointers you guys could throw my way would be great.
http://gi171.photobucket.com/groups/...4EBEL/box1.jpg
Old 04-26-2012, 07:18 PM
ChanCon's Avatar
0/11 ssssss446
Bumpity?
Old 04-26-2012, 07:26 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
honestly may be hard to make a wall that small.lol. other than that, i think you should come down a little or port area. 100-110" tops for a daily setup
-Youtube Channel
Old 04-26-2012, 07:28 PM
younggunzbass01's Avatar
0/11 sssss1653
It would have to be either super shallow or really narrow with a big baffle piece lol. any reason for only doing 4? Why not 6 or 8 in a clam?
Old 04-26-2012, 07:36 PM
ChanCon's Avatar
0/11 ssssss446
I'd like to keep my bed space and not have to cut a hole for a blowthrough so I'm trying to fit a wall. from the floor I have 15" to work with and at the headrests I've probably got 10-12" to the back glass. Im planning on welding up a base for the box that will rise 10" off the floor so I can fit my batteries and subs underneath it i've got plenty of width and height to work with, depth is my only issue. So if I could find a way to make this work, under 100" port area? What should I be shooting for? I've always been kind confused about the port area debacle. Sorry for noob questions.
Old 04-26-2012, 07:39 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
6.5-7 cubes with 15" per would be more than enough
-Youtube Channel
Old 04-26-2012, 07:53 PM
niteryda's Avatar
im "E Thug" sukka
0/11 sssss3259
Take ur total port area n divide it by ur net cubic foot of ur box(after sub n brace disp), the final number should be betweein 13.5-15, thats great for musical, n 2 saz-3500s?, thats too much power for them with that big of a box, even with box rise, iirc those amps do around 4000 watts at 14v n 1 ohm, if u wire each amp to 1 ohm then i hope ur imp rises to 3ohms n voltage drops to 11.8 for 2200 watts , usually the bigger the box, the easier they r to unload with lots of juice, but i guess u can fine tune each amp to give the best
2000 Pontiac Sunfire SE (239,000+ miles)
2 AQ3500D.1 (1 being used so far)
4 15" Nightshade v1
4 15" FI BTL N2 (1 being used)
3.5 net @ 29hz
3 crescendo 1000c4 (1 being used so far)
Bought From - Lots of people
Sold To - Myself
Traded With - DevinG17
Old 04-26-2012, 08:01 PM
ChanCon's Avatar
0/11 ssssss446
Yeah it would be on just one 3500. Thanks for the great info though! Im still kinda in the learn everything I can stage as far as box specs and tuning goes.
Old 04-26-2012, 08:19 PM
niteryda's Avatar
im "E Thug" sukka
0/11 sssss3259
Omg man im sorry, i just seen that there was no "s" after 3500 up there, i added my own s, another way to find out ur final port area, u can take 13.5-15 n multiply that by ur net cu ft, thatll get ur final port area (ex 7cubes n 15 per = 105 sq inches), u can do the division way or the multiply way, which ever works easiest for u, i switch off
4 15" Nightshade v1
3.5 net @ 29hz
Sold To - Myself
wall guys help please. single psi 15 wall or not? blk1990gt Enclosure Discussion & Design Construction Help 1 04-18-2012 09:39 PM
civic hatchback-to wall or not to wall? Dbmonster Enclosure Discussion & Design Construction Help 2 12-14-2010 02:12 PM
Ridiculous BLAZER -- 153.4db on Termlab sealed w/ 4 12s, NO WALL!! RidiculousSoundz Car Audio Videos 10 09-25-2010 09:57 AM
team vxincar tunnel wall build 12x 12s and 9k of power astra van w reg 2000 vxincar Build Logs 60 09-14-2010 05:58 PM
8 12s in a sealed wall?? Yes/No BigC-Expo General Car Audio Discussion & Questions 16 08-01-2010 11:26 AM
