Removable slot ports - Car Audio Classifieds!
Old 04-28-2012, 01:53 PM
BASSNUT
0/11 ssssss180
Default Removable slot ports
Im just curious as to how many people have done this design on a box? How did/does it sound and how did/does it hold up? I just built a side ported box for my 2 sundown sa 8s with a removable slot port, I havent had a chance yet to see how it sounds because I've goda recone the suvs and my amp first comes in monday.
team sedatephobia
2 AQ HDC3-10s
DC Audio 3.5kw
143.9DB
Old 04-28-2012, 02:15 PM
robman's Avatar
DC AUDIO!!!
0/11 ssssss427
im currently building mine with interchangable ports. i hope it works grand
Old 04-28-2012, 02:31 PM
BASSNUT
0/11 ssssss180
Pics?
team sedatephobia
2 AQ HDC3-10s
DC Audio 3.5kw
143.9DB
Old 04-28-2012, 02:51 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Aslong as it's well designed/built it should perform just like a solid box, I always like to use anchors with machine scews/bolts and weatherstripping for sealing like in this build (it's just a removeable panel but same idea as a removeable port wall):
Enclosure Build: 4th order SA8s for dacheatham
Louder. Lower.
Team Tupperware
Old 04-28-2012, 05:02 PM
robman's Avatar
DC AUDIO!!!
0/11 ssssss427
do you think will mine if i put that sealing foam stuff and bolt every 4.5 inches it'll work right?
Old 04-28-2012, 05:08 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Do you mean to just change the tuning a bit or switching between a daily and SPL tune?
I'm actually in the middle of building one right now. I have a bet with a friend that it won't be more than .5 of a difference. I'll let you know.
I don't see many of them done, but that guy on here with the BMW and pair HDC4's has a port insert. He never did let us in on the gain between the two though.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 04-28-2012, 05:12 PM
robman's Avatar
DC AUDIO!!!
0/11 ssssss427
ya, between daily and spl, daily will be about 16" deep and other... well i might have to build a few to figure out what peaks best
slot ports cush man Enclosure Discussion & Design Construction Help 0 12-12-2011 09:15 PM
slot ports cush man Enclosure Discussion & Design Construction Help 0 12-11-2011 12:38 AM
Multiple slot ports Matt3824 Enclosure Discussion & Design Construction Help 2 09-19-2011 12:50 AM
Slot ports vs aero ports? 87linkin General Car Audio Discussion & Questions 6 01-16-2010 04:09 PM
Removable Ports? dak446 General Car Audio Discussion & Questions 19 09-24-2009 05:21 PM
