Aero mounting. - Car Audio Classifieds!
Old 04-28-2012, 11:15 PM
0/11 ssssss639
Default Aero mounting.
How do you guys mount aero's to your boxes? Obviously screws, but I am a bit weary of over-tightening and cracking something, or having it too loose. How do you guys do it? I've never used an aero before.
Old 04-28-2012, 11:28 PM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
Mine is partially external so I didn't mount with anything but silicone and gorilla tape for the time being...Seems to hold up pretty damn well so far!
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
Old 04-28-2012, 11:32 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Yep, yep. Silicone and duct tape. Aeros really don't take the beating that you might think.
Unless you just want it flush, then you should use some screws. The flange isn't as rigid as you may think. Put some weatherstrip underneath the mounting flare flange for a gasket. That will help with overtightening.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 04-28-2012, 11:41 PM
Man Behind the Curtain
0/11 sssss1699
Use the right screws and you won't ever crack them.
Old 04-28-2012, 11:45 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
You got some magic screws or what?
4x world champ
- Floyd E. Toole
0/11 ssssss639
and the right screws would be...
Old 04-28-2012, 11:59 PM
niteryda's Avatar
im "E Thug" sukka
0/11 sssss3259
hand tighten the screws, ull know when to stop before cracking, then put a lil ca glue overlapping the screw head n spray activator n the screws wont come loose, n later when u want to take the screws out, use a flat head on the ca glue n light tap with a hammer
2000 Pontiac Sunfire SE (239,000+ miles)
2 AQ3500D.1 (1 being used so far)
4 15" Nightshade v1
4 15" FI BTL N2 (1 being used)
3.5 net @ 29hz
3 crescendo 1000c4 (1 being used so far)
Bought From - Lots of people
Sold To - Myself
Traded With - DevinG17
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
Something like this pan head screw that is flat on the bottom of the head
Rather than a tapered screw head like this
Old 04-29-2012, 12:01 AM
0/11 sssss1699
Any type of plastic you NEVER want to use a screw/bolt that has a tapered head, such has a flat head (drywall screw) thats made to be countersunk. You want to use a head that is flat on it's bottom. To flush these you use a couterbore. When you use one that is tapered, you create a sheering/wedge effect when tightening down the screw/bolt and you introduce lots of stress into the hole. Heads with flat bottoms don't introduce this stress, instead they put all pressure downward, instead of down and out. Plastics don't like high stress point areas like screw holes or 90 degree inside corners. Making inside corners with plastic you want a radius, this helps with stresses and saves cracking.
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
You can murder the flange with those too, man. Lol.
Just don't overtighten the damn thing.
4x world champ
- Floyd E. Toole
mounting depth OlDD84 General Car Audio Discussion & Questions 3 03-27-2012 07:18 PM
Sub Mounting Help.... jhg33k General Car Audio Discussion & Questions 8 01-23-2012 09:08 PM
Mounting depth red08yaris Enclosure Discussion & Design Construction Help 1 04-13-2011 10:00 PM
SA-8 mounting gaskets tacomaguy1 (Sundown Audio) 1 10-19-2010 06:24 PM
sa-8 mounting? luises14 (Sundown Audio) 9 03-24-2010 09:24 AM
