Port Design Help - Car Audio Classifieds!
Old 04-29-2012, 06:29 AM
0/11 sssssss12
Default Port Design Help
Hey guys im making a custom ported box for my Audiobahn AW1805Q Reconed by psi for 2k + rms.
so far my measurements are 14" high, 47" wide , 21.35" deep. at 5.8 cuft after sub displacement 1" thick mdf.
im after a Slot port tuned to 32hz,
could someone help me out with a sketch of lengths i should use for the port? as im not to sure how to do it without getting massive port noise. ( used aero's before ) But will 3 4" aero's be enough? at 12.6" long
and will my Box need bracing if im only running 1.8 -2k rms?
cheers Blake
Old 04-29-2012, 07:52 AM
vince79vette's Avatar
0/11 sssss2011
Try re audio box calculator it's pretty good for doing slotted ports
port design help ben031681 General Car Audio Discussion & Questions 0 05-05-2011 03:20 PM
Questions about port design maddog2099 General Car Audio Discussion & Questions 1 08-30-2010 07:42 PM
Help on port design? SUBW123 General Car Audio Discussion & Questions 15 08-23-2010 06:04 PM
Working on a design, need some port info. tez4life General Car Audio Discussion & Questions 2 08-06-2010 09:11 PM
box design port ? 98Expo Enclosure Discussion & Design Construction Help 4 06-17-2010 06:45 PM
