Resin help, inside box - Car Audio Classifieds!
Old 04-29-2012, 07:01 PM
SWIFT's Avatar
0/11 ssssss656
Default Resin help, inside box
So I have gotten bored looking at the box in garage waiting on the subs and decided to resin all corners and seams and maybe all inside just for the hell of it. Well this has created a nightmare, 90% is hard as a rock but the corners in some places will not completely harden and are still tacky after 2 days. I have read leave it alone and it will eventually harden but this is BS. I don't know whether to scrape or try to sand it down bare again or what. I tried another layer last night with a little more hardener but same thing. Tacky in some spots, I am regretting even doing it now. After over 300 bucks in just wood I don't want to screw it up. I think it's not hardening were the liquid nails sealed the corners.
Any ideas?
Old 04-29-2012, 07:11 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
Any ideas?
could be. i was told resin wouldn't adhere to stuff like that. i resin all my boxes which is why i use no sealer other than the gorilla wood glue.
My game is legit,
Old 04-29-2012, 07:19 PM
SWIFT's Avatar
0/11 ssssss656
That's what I'm worried about. Should I start scraping? I could use mat and resin over that in corners and seems but not in the port.
Can I even scrap this shit out?
The box is 14cuft of all high dollar nice baltic birch except port wall which is mdf.
Old 04-29-2012, 07:27 PM
badmofo529's Avatar
0/11 sssss3329
dont lay anymore mat, but mix up a little bit of resin extra hot and brush it on where it needs it
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
The Following User Says Thank You to badmofo529 For This Useful Post:
SWIFT (04-30-2012)
Old 04-29-2012, 07:34 PM
0/11 ssssss577
set a space heater in the box for a few hours and it will harden
The Following User Says Thank You to harrisondesigns For This Useful Post:
SWIFT (04-30-2012)
Old 04-29-2012, 07:38 PM
serjr711's Avatar
0/11 sssss2699
Feedback Score: 65 reviews
This is what I use. Do you have a Tap Plastics in town?.
TAP Surface Curing Agent : TAP Plastics
Old 04-29-2012, 07:40 PM
SWIFT's Avatar
0/11 ssssss656
I will try a couple things, I have a small work light that puts off massive heat. I will set it in there and see what happens. Sucks because I don't want to upholstery it until this is done
Old 04-29-2012, 08:01 PM
0/11 ssssss577
the light should do it, set it quite close and move it ever hour
Old 04-30-2012, 10:45 PM
SWIFT's Avatar
0/11 ssssss656
Ok nothing has worked, lessen here is never use liquid nails and think resin will do well as a top coat. Lots of scraping and then broke out the sander. Trying to sand this shit out. Only thing working at this point. Sucks but got to have this complete this week. Wife needs garage for a freakin yard sale.
After all this I will wipe all down with wet rag and attempt a thin coat of spray paint just to insure there is not fiberglass dust blowing around in my truck when subs are playing.
I know one thing this sucks
Old 04-30-2012, 10:48 PM
3rdshiftdiscretion's Avatar
CACO Late Night Crew
0/11 sssss4240
Feedback Score: 30 reviews
mix some resin super hot and put it on.
Bewbs
The Following User Says Thank You to 3rdshiftdiscretion For This Useful Post:
nelsonmandela27 (05-01-2012)
Fiberglass Resin for Subwoofer Box Benzino713 Sound Deadening & Fabrication 27 05-05-2012 09:24 PM
How to resin inside box? nicholask1993 General Car Audio Discussion & Questions 16 11-18-2011 10:27 PM
Resin inside box Memphistahoe02 General Car Audio Discussion & Questions 12 08-19-2010 12:02 AM
resin inside box gbo559 Enclosure Discussion & Design Construction Help 14 12-18-2009 06:59 PM
Resin on the inside of the box? Worth it? CleanNMean General Car Audio Discussion & Questions 0 09-30-2009 08:46 AM
