Impedance rise....fml - Car Audio Classifieds!
Old 05-01-2012, 02:52 AM
hardrock2401's Avatar
0/11 ssssss219
Unhappy Impedance rise....fml
Right now I am on my second box of trying to keep my impedance rise down, and failed miserably. This is for a trunk car, both port and sub facing trunk (I dont want a fwd facing box because all lows are muted unless completely sealed, and dont want to do that)
My first box failed, few people gave me advice to make the box short and wide to help with efficiency. This is for a single 12 btw, box is 2.4cu after all disp. and tuned to 33hz. 13in tall, 35wide, and i believe 22 deep with 47sq in of port.
I am starting at 1 ohm and raising to 5.4 on a m3a, still clamping 1600w tho.
Any ideas on what i could improve on
2004 Civic Si - K20a2/6spd swap, First gen Fi Q on a Twisted Sounds 1.3k
2015 Veloster turbo 6spd - stock daily driver
1986 Fiero GT - Pride and joy, awaiting a L67 swap
Old 05-01-2012, 03:02 AM
0/11 sssss1475
Aeroport? Possibly a smaller box? That's almost a cubic foot more than DC spec's. What coils does your sub have?
Old 05-01-2012, 03:17 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
direct leads, .5 nominal.
Current Build:
#60sHereIcome
Old 05-01-2012, 03:23 AM
0/11 ssssss219
It's a ufo mag btl, I only had the xl in while i was reconing the btl
its a d2, I'm not runnning at .5 to cover up a inefficient box
Old 05-01-2012, 03:27 AM
SINTORMAN's Avatar
0/11 sssss4907
well that would probably make the easiest biggest impact on your rise.
Current Build:
#60sHereIcome
Old 05-01-2012, 03:31 AM
0/11 ssssss219
I want to learn how to make a box more efficient, not how to make my amp more inefficient...if I wanted to do that I wouldnt be asking for box design help
Old 05-01-2012, 03:33 AM
SINTORMAN's Avatar
0/11 sssss4907
build a tline?
Current Build:
#60sHereIcome
Old 05-01-2012, 03:36 AM
NoPh33rRaCiNg's Avatar
I <3 ( . )( . )'s
0/11 sssss3010
Feedback Score: 29 reviews
nvm: you have enough port
Team DC Audio : Team NWSPL : Team Shok
02 Tahoe - (1) 15'' XL, Shok II, Shok 1/0
03 S10 (in progress) - (3) 15'' Lvl5's, (2) DC 5k's, lots of Shok 1/0
Old 05-01-2012, 03:38 AM
0/11 ssssss219
Would I be able to fit a tline with those measurements? I can't go any bigger, I have my trunk tapped out with those
Old 05-01-2012, 03:49 AM
0/11 sssss1475
Have you tried different frequencies?
Impedance Rise quaddropper General Car Audio Discussion & Questions 10 01-31-2011 01:52 PM
Impedance rise Bigbodylexus (Sundown Audio) 6 11-16-2010 01:20 PM
question about impedance rise Craig28 General Car Audio Discussion & Questions 11 07-16-2010 03:54 PM
box and impedance rise MiX General Car Audio Discussion & Questions 20 05-26-2010 07:31 PM
calculating impedance rise? F3M4 General Car Audio Discussion & Questions 4 07-15-2009 11:27 PM
