who uses torres box calculator? - Car Audio Classifieds!
Old 05-03-2012, 10:11 PM
0/11 ssssss249
Default who uses torres box calculator?
Ok i downloaded/bought the subwoofer design toolbox. The only problem i have with it when designing a ported box is it doesnt calculate net volume after port, driver and bracing displacement. I downloaded the torres program and it does do all of this i am just a freak and want to hear some other input as to how accurate it is. Just to answer all the required questions the box is for 2 10 inch fi ssd's. Net volume is 2.84ft3 tuned to 31hz. The dimensions of the enclosure are height16xwidth34xdepth17. Port height 14.5 port width 3 port length is 37 but in this calculator it gives a second value of physical port length:33.25 this has me a little puzzled if someone could please explain this? amp is a hifonics bxi 2610d 1x1700 rms @2ohms. Going into a chevy silverado crew cab.Thank you in advance for any wisdom-Dave.
Old 05-03-2012, 10:22 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
You bought torres when its free?
Old 05-03-2012, 10:23 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Also, you have to plug in the numbers for displacements, it doesn't just do it for you automatically.
Old 05-03-2012, 10:48 PM
0/11 ssssss249
Default ...
No i bought the subwoofer design toolbox. I know i have to plug in displacements But torres calculates port volume for you where subwoofer design toolbox doesnt.
Old 05-03-2012, 10:58 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
It's accurate enought to no worry about. That's what I use and my designs have been verified by box builders.
Sent from the E lab.
Old 05-03-2012, 11:03 PM
0/11 sssss2298
Feedback Score: 54 reviews
I use it and think its pretty darn accurate.
Old 05-03-2012, 11:06 PM
0/11 ssssss249
Default ...
Thanks for replies. Just one other question do you use a common chamber for your vented enclosures? That is also part of my plan it makes building the enclosure so much simpler. i understand that if one of the subs fails the other will be damaged but i double and triple check my installs and set amplifiers with dmm .
Torres sub box calculator help needed mineralgrey01gt Enclosure Discussion & Design Construction Help 6 02-03-2012 09:43 PM
torres box calculator and tablet kansas39503 Off Topic Chat 0 08-24-2011 09:28 PM
Torres box calculator HELP!!! loudernu Enclosure Discussion & Design Construction Help 1 05-28-2011 06:59 AM
Re audio box calculator ? silveradothump Enclosure Discussion & Design Construction Help 10 04-18-2011 09:56 PM
torres box tuning problem Russellabt General Car Audio Discussion & Questions 2 03-26-2011 03:18 PM
