need help designing 4th order for two 15"s - Car Audio Classifieds!
Old 05-04-2012, 05:46 PM
0/11 sssssss83
Default need help designing 4th order for two 15"s
i need help designing a 4th order for two poweracoustik mofo 152x's. i have 35"wide by 18" high and 28" deep. any help appreciated
Old 05-05-2012, 12:45 AM
0/11 sssssss83
or what ever will get pretty loud and sound good. i had alot of port noise from my old box can some one please help
Old 05-05-2012, 04:22 PM
0/11 ssssss639
I really doubt that is enough room for a 4th order for two 15"s. I had a 4th for 2 12" VVX's in a 36x16x20 box (if memory serves me right) and i had to build most of it IN my trunk. It just barely fit. Why not just do a ported box?
Old 05-05-2012, 08:05 PM
For the depth, make the sealed portion 8" deep, and the vented portion 20" (or whatever you have left over after wood thickness) deep. You won't be able to fit a huge port in there though, so i suggest going external. That will give you about 3ft^3 sealed and 7ft^3 ported, depending on other displacements. It's probably barely enough; if you can expand any of those numbers by even an inch or two it will help.
Old 05-05-2012, 11:23 PM
0/11 sssssss83
i can make an external port pretty much any length, im using my old box and rebuilding inside just to see how it sounds
4th order for SX 15" taylorpro Enclosure Discussion & Design Construction Help 2 10-21-2010 08:53 AM
4th order for HDC3 15" taylorpro Enclosure Discussion & Design Construction Help 6 09-09-2010 09:39 AM
4 18" 4th order... Scapelli21 General Car Audio Discussion & Questions 25 07-02-2010 04:32 PM
10" 4th order grimreper912003 Enclosure Discussion & Design Construction Help 12 01-28-2010 09:40 AM
2 10"s 4th Order rmzsuzuki89 Build Logs 36 12-06-2009 07:56 PM
