sundown trunk fourth - Car Audio Classifieds!
Old 05-07-2012, 12:51 PM
0/11 ssssss518
Default sundown trunk fourth
Im coming home from school this thursday and I will be getting a car here shortly, hopefully a Acura TL, I plan to build as big of a box as possible in the trunk and port through the ski-hole with a 8 in aero.
Subs: 2 zv3 12s
Amp: ns1 @.2 (until i get electrical for .5)
Im shooting for as much lowend output as possible with realatively flat response from 20 to 45hz. Im thinking i can fit at least 8 cubes gross and im willing to build the box inside the car and go as big as possible.
Im thinking a 3:1 ratio tuned to 45hz
Anyone else have any opinions?
Old 05-07-2012, 01:01 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
@ .2? You know thats lower than .5 right?
Old 05-07-2012, 01:03 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
The older TL's had factory sub in the rear deck right? I'd port it through there. And why such a small bandwith? i'd go for 25-55. Anything below 25 is useless unless you have tons of cone area or a huge bandpass
ChanCon's Avatar
CACO Late Night Crew
0/11 ssssss446
lol yeah .2 is gonna assplow your electrical
The Following User Says Thank You to ChanCon For This Useful Post:
KTMrida4life (05-07-2012)
Old 05-07-2012, 01:04 PM
badmofo529's Avatar
0/11 sssss3329
make sure you have a removable panel. you are gonna be reconing alot @ .5...
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
I dont think he ment to put the "." there. Im sure he ment 2 ohms
Old 05-07-2012, 01:08 PM
ChanCon's Avatar
0/11 ssssss446
yeah that would make sense since you could wire dual 2s either way
Old 05-07-2012, 01:10 PM
Infinitelybaffled's Avatar
0/11 ssssss816
NNNNNNNNNNNNNOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOBB BBBBBBBBBBBBBBB!!!!!!!!!!!!!!!!!!!!!!!! 3:1 Tuned to whatever you want sounds fine to me.
Inappropriate sig image.
Old 05-07-2012, 02:16 PM
0/11 ssssss518
I meant to say 2ohm haha
Old 05-07-2012, 02:29 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
20-45 is over an octave. same as 30-67hz
20-45 is a fairly wide bandwidth, however will need some midbass to pick up from 45- ~80hz
The Following User Says Thank You to profundus-sanus For This Useful Post:
loganuf (05-07-2012)
152+ on two Sundown z12v3's and an NS-1 ....loud trunk yo Skillz (Sundown Audio) 44 06-20-2012 09:08 AM
Sundown Audio SA 10's TRUNK Build Oldbass38 Build Logs 11 04-13-2012 08:32 PM
2 12s in a fourth or sixth order in trunk dirtrider Enclosure Discussion & Design Construction Help 49 07-25-2011 03:55 PM
Trunk 0-1000 Sundown and Crunch :P mbrooky Car Audio Videos 21 06-02-2011 04:15 PM
Sundown Trunk Build Derrick824 (Sundown Audio) 145 05-19-2011 07:08 AM
