Basics for a wall? - Car Audio Classifieds!
Old 05-08-2012, 01:47 PM
vince79vette's Avatar
0/11 sssss2011
Default Basics for a wall?
I am doing my first wall and want to know what I should do far as planing and building and size and port. I am doing 4 hdc3 18s on 8k in jeep Cherokee
Old 05-08-2012, 01:48 PM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
is that gonna fit? have u measured yet
you probably wont like me
Old 05-08-2012, 01:52 PM
0/11 sssss2011
Ya I can do about 52 across up front but after 2 feet I have to taper it down because of the fender wells to 42 across but I can do 50 high if I can remember right
Old 05-08-2012, 02:13 PM
0/11 sssss2011
Anyone
Old 05-08-2012, 02:35 PM
upzaw2000's Avatar
0/11 ssss14427
figure out how much space u need for subs and port, tuning frequency.
do you want to build the box inside the car or build it outside and slide it through the back.
gotta build the floor up ecspecially if there is a hump at all.
what kinda wall you wanna do? flat with a port to the side? Bottom? Top?
I think as far as spl goes the best way to go is off to the side.
build it on paper first... then make it happen
The Following User Says Thank You to upzaw2000 For This Useful Post:
iamsonic (05-08-2012)
Old 05-08-2012, 02:37 PM
AllenH427's Avatar
0/11 ssssss841
Do not do an L-Port, properly brace the crap out of it.
TEAM XS - MECHMAN - FI - AUDIOQUE
152.6 OUTLAW AND CLIMBING
Old 05-08-2012, 02:44 PM
0/11 sssss2011
I want to build it in the jeep that why i am asking if others have done walls in there cars. I want to do 2x4 framing and have a flat wall with port on driver side(everyone says that best for spl.) mount the amps on the side on a floating board(to cut down on vibration) and have the batteries right behind the seats.
Old 05-08-2012, 02:52 PM
tacomaguy1's Avatar
0/11 sssss4401
sounds like you have the idea...get to it
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 05-08-2012, 02:54 PM
0/11 ssss31258
amps and batteries in the hatch is easier.
making the drivers seat be able to slide back / recline into the port opening would be convenient.
The rest is just a matter of building it.
Old 05-08-2012, 03:18 PM
upzaw2000's Avatar
0/11 ssss14427
theres no secrets.... there is a lot of build logs,
its just one of those things u gotta do and if its your first one you will learn alot of what not to do.
look over the build logs...
keep it simple with the mind set of..... its just a box.... and then u use panels to seal off the rest of the car.
niteryda (05-08-2012)
Teaching You The Basics! NoPh33rRaCiNg Off Topic Chat 1 04-25-2012 09:12 PM
back to the basics nuboot Team Teamless 4 03-20-2011 10:05 AM
clam and diamond basics Kyle K General Car Audio Discussion & Questions 24 08-23-2010 07:20 PM
Passive Radiators: The Basics madmat Tutorials & Quick References 0 10-28-2009 07:22 PM
Basics of wiring speakers forceww Tutorials & Quick References 3 09-30-2008 08:28 AM
