power handling with relevance to box and port size - Car Audio Classifieds!
Old 05-08-2012, 11:50 PM
0/11 sssss1237
Default power handling with relevance to box and port size
question about power handling with relevance mainly to port size and box size.
if i have a port ratio that is closer to say 12 than 16 (when you take port area divided by cubes of box) would it have better power handling and cone control? or would a box designed more for spl and more port area be designed for better power handling?
MY second question is:
if you have same amount of space say 8.5 cubes to work with for 2 15s,
port area is 89 sq in, if changed to a higher port area say 96, and subtracted from the box area, it would give me a higher ratio to 16, better for spl, but will it be better for more power handling?
**not trying to hit any rediculous 15hz stuff, just trying to get loud daily driving tuning 34 hz
Old 05-09-2012, 07:40 AM
0/11 sssss1237
bump no one"
Old 05-09-2012, 07:43 AM
younggunzbass01's Avatar
0/11 sssss1653
Lower port area lets you play lower, hence controlling the cone better and creates more port velocity. Which IMO exchanges more air in and out of the box and helps with cooling. What 15's?
Old 05-09-2012, 12:56 PM
BASSNUT
0/11 ssssss180
I personally usually figure closer to 12sqin/cubic foot because i think there is a slight difference in how it sounds. but all the "loud" people use more port area lol
team sedatephobia
2 AQ HDC3-10s
DC Audio 3.5kw
143.9DB
Old 05-10-2012, 07:40 AM
0/11 sssss1237
assdfghjk
SA 15s box size and port area help?? tez4life (Sundown Audio) 4 05-20-2011 04:49 PM
Port size for 2 sa-10s in 3cu. box [email protected] Enclosure Discussion & Design Construction Help 5 04-11-2011 11:47 PM
Questions about box/port size/hz tuning KRestevan Enclosure Discussion & Design Construction Help 1 03-25-2010 07:27 AM
I have a 9.5 cubed box for one sub want should be my port size. More spl Enclosure Discussion & Design Construction Help 8 03-22-2010 08:22 AM
Box and Port size RD HW 18 Drock040687 General Car Audio Discussion & Questions 44 11-28-2009 07:12 PM
