two 15's?? - Car Audio Classifieds!
Old 05-10-2012, 02:22 PM
0/11 ssssss227
Default two 15's??
i can fit two of them in my trunk firing forward...if i get like two 1.5" aero's?? maybe 2" aeros?? would this work? im jw and i can ,ale the space in the trunk for the box...im just curious to know if i can have ports set up like that for them...? any input is appreciated (id rather not do port firing off to one side)
Old 05-11-2012, 04:03 AM
0/11 ssssss227
any input??
Old 05-11-2012, 07:30 AM
jorgesau100's Avatar
160+ DD ftw
0/11 ssssss424
I would not do that. that's way to lil port area if any thing you can do subs frount port to the driver side just give some space around the box so the sound can go around
Old 05-11-2012, 08:07 AM
chapdawg1971's Avatar
Semi-Loud Trunk
0/11 sssss1950
Feedback Score: 25 reviews
What car?
I am here: http://tapatalk.com/map.php?5d3ub2
Sent from my iPhone 4S using Tapatalk
4th USACI WF 2011 Trunk 0-1K 154.3db
157.??....and done.
Old 05-11-2012, 08:11 AM
chrishova's Avatar
Eight 12''s
0/11 ssssss703
I tried cramming 2 15"sin my trunk , I blew them and got one and it was louder than the two! Now I got a single SMD...
sent from my galaxy....
'97 Grand Prix GT 3.8
5 Black Cherries
Eight SA 12''s on a DDz2
Old 05-11-2012, 08:24 AM
Semi-Loud Trunk
0/11 sssss1950
I got em in my Saturn...
I am here: http://tapatalk.com/map.php?tq0agn
157.??....and done.
Old 05-11-2012, 08:36 AM
0/11 ssssss386
Yea that not enough port area to make any good sub happy. Is there any space below woofers that leads into the spare time well? In my trunk I am building the port right below the 2/15s and the port extends in the spare tire well about 20 inches. I was able to get 85 sq inches of port are thAT way. I am not sure how well it will work and it is a major custom engineering job involving lots if fiberglass.
If you don't want do all that I would think about 2/12s or a single 15 or 18 front firing. That way you can get the port area the subs will need. I ran a single 18 last year forward firing and had great results.
2013 and 2011 Midwest SPL Extreme Trunk Champ
94 Honda Accord
Two DD 9915 SC front firing out of the trunk
2 DD M4a's
Old 05-11-2012, 09:10 AM
Anton Miller's Avatar
DoucheMiller
0/11 sssss3720
2 15's would be a biatch to fit in a cavalier, you would have to go with single layer on sides and bottom double layer on top and back and baffle. even then you can only fit a 4.5" wide slot port
heres my concept of what it would look like in my cavalier:
1997 CHEVY CAVALIER - BUILT FOR EFFICIENCY!! YOUTUBE:
Old 05-11-2012, 09:48 AM
Semi-Loud Trunk
0/11 sssss1950
Yep.....would all be dependent on your goals.
I am here: http://tapatalk.com/map.php?fhtraz
157.??....and done.
Old 05-11-2012, 11:29 PM
0/11 ssssss227
i get free/cheap steel Anton, so i can brace the hell out of the corners and sides if need be i can get as thick as i need (up to quarter plate i believe)
12 15's dc audio jeep, ryans 4 15's codys 1 18 etc! T3audioNavi Car Audio Videos 7 04-07-2011 05:01 PM
(4) sdc2.5 15's vs. (2) mtx 9500 15's? Dbmonster General Car Audio Discussion & Questions 9 08-12-2010 01:11 AM
2 aq hdc3 15's vs 2 dc level 4 15's hdman87 General Car Audio Discussion & Questions 17 07-08-2010 08:49 PM
2x custom D1 15's + Dual 15's box w/ 10.5" Alum Flared Aero snb778 15" Subwoofers 13 02-08-2010 03:15 AM
(4) Memphis MOJO 15's reconed with FI parts WTTF for 2 B.A. 15's 18inchjeepin Car Audio Trader (WTT) 6 01-22-2010 05:30 PM
