2 12 Type r 4th order - Car Audio Classifieds!
Old 05-11-2012, 07:54 AM
drsnazzy's Avatar
Noob haha ;)
0/11 ssssss392
Default 2 12 Type r 4th order
SORRY I PUT MY OTHER THREAD IN THE WRONG SECTION
Looking to build a 4th order for my 2 12 type r, the older style (500rms lol) with the big r on the darker cone.
What i have though up so far,
Ported Section- 3cubes tuned to 46hz, center port
Sealed section- 1.5 cubes
Just looking for other input
Ill be running them on a powerbass 1500, @1ohm
Old 05-11-2012, 07:56 AM
drsnazzy's Avatar
Noob haha ;)
0/11 ssssss392
im looking to ground pound the lows
Old 05-14-2012, 05:54 PM
drsnazzy's Avatar
Noob haha ;)
0/11 ssssss392
• Ported- 3.1 cubes, @46 hz
• Sealed- 1.5 cubes
Port specs- 6in W, 7in High (does this sound right)?
Ported chamber specs: 27w X 16h X 16d – 3.1 cubes
Sealed chamber Specs: 27w X 16h X 8.5d – 1.5 cubes
__________________________________________________ __
thats what i have came up with so far.
Im getting confused when it comes to making a cut sheet, could someone help me out?
Old 05-15-2012, 01:15 AM
drsnazzy's Avatar
Noob haha ;)
0/11 ssssss392
Help please?
Sent from my LS670 using Tapatalk 2
Old 05-15-2012, 01:47 AM
0/11 ssssss888
Doesn't look too bad from what I know. Could possibly go bigger on the ported side however if you do you'll lose frequency range. Build, then test, then rebuild, till your happy. I like aero's too for ease of tuning.
Team Lethal Beatz
Alpine 9886
2 st350's, 2 Eminence alpha 10's
MB Quart DSC2150
MB Quart DSC4125
4 RD sonances
2 IA 20.1's Strapped at 1 ohm
4 Deka 9a31's
220A alt
Wall tuned at 29 hz
Old 05-15-2012, 04:20 PM
drsnazzy's Avatar
Noob haha ;)
0/11 ssssss392
If I wanted 46hz what aeros should I use and what lengths
Old 05-15-2012, 04:41 PM
Slaughterhouse's Avatar
0/11 ssssss868
Products Menu
You're welcome
* TC Sounds, Arc Audio, Hybrid Audio, Sundown Audio, Brax Audio, Helix Audio, Sony XM, Focal, Morel, Hertz *
Old 05-15-2012, 04:42 PM
drsnazzy's Avatar
Noob haha ;)
0/11 ssssss392
What ports should I use to get 40in of port area with aeros
Old 05-15-2012, 04:46 PM
drsnazzy's Avatar
Noob haha ;)
0/11 ssssss392
I've never used aeros before, but honestly what would be the difference between aeros,
Or slot port either 6x7, or 12x3.5 in
Old 05-15-2012, 04:51 PM
drsnazzy's Avatar
Noob haha ;)
0/11 ssssss392
And from others experience does pvc pipe work well when used for ports?
Tags
4th order, alpine, type r
4th order for 2 12 type r drsnazzy Box Requests 4 05-11-2012 01:05 PM
4th order design for 4 Type-Rs surreal General Car Audio Discussion & Questions 16 09-13-2011 06:22 PM
4th order for 2 Type R 12's white4d96 Enclosure Discussion & Design Construction Help 4 09-17-2010 03:45 AM
12" Type R 4th order grimreper912003 Enclosure Discussion & Design Construction Help 11 03-10-2010 09:50 PM
4th order bandpass, two Type R 12's white4d96 Enclosure Discussion & Design Construction Help 0 11-07-2009 04:08 PM
