Port below the woofers ? - Car Audio Classifieds!
Old 05-14-2012, 04:00 PM
0/11 ssssss386
Question Port below the woofers ?
Just curious has anyone out there ever built a box with the port below a pair of woofers? If so did you notice any issues?
I am in the middle of building a box for two 15's (sealed off, front firing) for my trunk and I am using the area below them which leads into my spare tire well as the port. I had no other options. I don't think there will be any issues and it is too late now for me to start over.
But I might as well ask to see what others have experienced.
2013 and 2011 Midwest SPL Extreme Trunk Champ
94 Honda Accord
Two DD 9915 SC front firing out of the trunk
2 DD M4a's
Old 05-14-2012, 04:47 PM
05TRAILBLAZER's Avatar
i ♥ Sundown Audio
0/11 sssss1946
subs up i suppose?
Old 05-14-2012, 05:08 PM
0/11 ssssss386
its in a trunk, subs forward, and port forward, sealed off from the trunk.
There was "cavity" that slopes down into my spare tire well, it just looked like it wanted to be made into a port... so I am doing it. I got 85 sq inches of port out it. I think it will work ok or at least I am going to find out.
94 Honda Accord
2 DD M4a's
Old 05-14-2012, 05:16 PM
i ♥ Sundown Audio
0/11 sssss1946
idk man never thought of that might just work who knows good luck!
Old 05-14-2012, 05:53 PM
chapdawg1971's Avatar
Semi-Loud Trunk
0/11 sssss1950
Feedback Score: 25 reviews
Pics of the area?
I am here: http://tapatalk.com/map.php?zhb3ym
Sent from my iPhone 4S using Tapatalk
4th USACI WF 2011 Trunk 0-1K 154.3db
157.??....and done.
Old 05-17-2012, 05:35 PM
0/11 ssssss386
Here are pics of what I am talking about...I have already started this so I will be answering my own question as to whether by idea will work or fail.
I guess I should start a build log too.
Let me know if you think the port location will work or not.. or if you have ever seen or built a port like this please let me know if it worked or not.
By the way, the port area gives me about 85 sq inches of port for 6 cubes/2-15's.
94 Honda Accord
2 DD M4a's
Old 05-25-2012, 01:29 AM
GiGLZ's Avatar
0/11 ssssss514
i would dampen right under the port if u havent
Tags
port below subs, trunk
Cartunz 3X show 6-24-2012 $500 for loudest non Port or Super Port score bdufner Competition Corner 2 06-16-2012 07:29 AM
