2 12s 4th order or 15s ported? - Car Audio Classifieds!
Old 05-15-2012, 02:37 PM
0/11 sssss1406
Default 2 12s 4th order or 15s ported?
Same as title.
Which one would be better for a daily loud ground pounder that moves a lot of air.
Also which will use a smaller box?
Old 05-15-2012, 02:41 PM
0/11 ssssss614
4th order will move more air in my opinion but dont get me wrong tunning a ported box low low can be achieved with great outcomes.
2 sundown sa 10z
4:1 4th order
sundown 1500d @.5
02 s10 147.3 (louder now) on the dash
Old 05-15-2012, 02:43 PM
mega fatty
0/11 sssss6008
2 15's will be better
Proper box for each they should be close in size but the 2 15's have more cone area
Just because it's a 4th doesn't make it some magical 5db gain enclosure
07 mazdaspeed3
rd d9 @ .5ohm
Old 05-15-2012, 02:49 PM
0/11 ssssss614
very much correct with that statement the 15s will have alot more cone area.
2 sundown sa 10z
4:1 4th order
sundown 1500d @.5
Old 05-15-2012, 02:52 PM
0/11 ssssss640
2 15s ftw
Old 05-15-2012, 03:19 PM
0/11 sssss1406
OK 2 15s it is, what other subs are like DC level 3m2s that I should look at? Likes small box low playing and works great around 1k a piece.
Old 05-15-2012, 03:20 PM
Matt3824's Avatar
0/11 sssss3754
SA's
0/11 ssssss579
SA-15s maybe
Old 05-15-2012, 03:22 PM
Supergumby5000's Avatar
0/11 ssssss642
The drivers will depict which enclosure will work better....
Old 05-15-2012, 03:58 PM
0/11 sssss1406
I'm going with ported 15s.
Arnt the SAs 2.5 in coils? I'd prefer 3in. Also it looks like the SAs would be happier with 4cubes per 15 oppose to DC wanting 3cubes.
Plus I heard the SAs are geared more towards SPLish oppose to liking lows. . . .
4th order or ported theking General Car Audio Discussion & Questions 27 10-18-2011 06:58 PM
ported and 4th order? Russellabt General Car Audio Discussion & Questions 3 10-11-2011 02:06 PM
2 15s ported or 4th order? rachidfunaki Enclosure Discussion & Design Construction Help 1 10-26-2010 04:55 AM
DC XL 15s in a 4th order bandpass or ported for daily?? tez4life (DC) 12 10-04-2010 03:35 AM
