Since im shrinking my box from 10 cubes to 8.5 do i still need both 8 " aero ports??? - Car Audio Classifieds!
Old 05-15-2012, 04:29 PM
0/11 sssss1785
Default Since im shrinking my box from 10 cubes to 8.5 do i still need both 8 " aero ports???
Since im shrinking my box from 10 cubes to 8.5 do i still need both 8 " aero ports I had two 8" aero ports in a box that was 9.83 to 10 cubes net but now im shrinking my box to 8 to 8.5 cubic ft net. Can i get away with only using one 8" aero port.
Old 06-03-2012, 12:35 PM
0/11 ssssss211
required port area has more to do with controlling vent air speed, which in turn depends on how much air the cone is moving. The more the cone is capable of moving, the more port area is needed to keep chuffing to a minimum; enclosure volume only plays a part on the actual tuning frequency, not the vent air speed.
Old 06-03-2012, 12:39 PM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
smaller box with same ports.... tuning goes up
Team AST-2 15" Everest Sound Labs Bdx.Powered by Flatline audio ba2
Team Psychoacoustics-11" Adjustable Psycho Port. 12 T3 Audio 6x9s for mids
Old 06-03-2012, 12:44 PM
0/11 ssssss211
absolutely.
So to answer the OP's question, yea you can IF your single 8" aeroport can keep the vent air speed below about mach 0.10 (around 35 m/s) while being long enough to achieve your target tuning frequency.
Old 06-03-2012, 12:49 PM
Do you even demo?
0/11 sssss1797
plug it off and listen to the port noise...just remeber just plugging one off will change your tuning a bunch
Old 06-03-2012, 12:54 PM
0/11 ssssss211
which is the exact reason you can't investigate port noise when it's not tuned the the target frequency--vent air speeds are dramatically different when tuned to 15Hz vs 50 Hz, even with the same input power. Luckily these kinds of things can be investigated with programs like WinISD, Bass, Box, Horn Response, and my personal favorite- Akabak.
Tags
aero port, sundown
Anybody have any good box designs for two zv3 18s using aero ports, no wall Mnorwood01 (Sundown Audio) 8 05-10-2012 06:29 PM
4" aero flared port kits - box ports - [email protected] Wiring, Electrical & Other Installation Equipment 7 10-20-2011 10:47 AM
dual 15 sub box with (3) 6" custom aero ports built by www.davetheboxguy.com stirfri4202 Craigslist Deals 0 09-14-2011 04:40 PM
aero ports for a 1 12" sub box...? allout13 General Car Audio Discussion & Questions 2 03-17-2009 01:44 PM
