1st ported enclosure build ?'s - Car Audio Classifieds!
Old 05-19-2012, 03:48 PM
0/11 ssssssss6
Default 1st ported enclosure build ?'s
Ok I will be attempting my 1st ported enclosure soon. Im wanting to tune it to 34hz, I listen to mostly rock music and am looking for sql. The box will be for 2 oldskool 10" Fusion powerplants.
I want to follow the contour of my back seat so the box fits against the back seat tight(im trying to keep as much room in rear cargo area as possible). Will the output of the box be hurt if the box is not square? Also I know this will screw with my port design right? If I do it this way the box will be a wedge style, the bottom will be 7 1/2 inches bigger than top. Im hoping id be able to maybe build it deep enough so the port would not need to go all the to the back of the enclosure...
Also should I build the box with 1 port or separate ports for each sub?
Thanks for all input!!
Enclosure Build: TheWaxShop's 18" ported, lowz Pioneer~Saturn Build Logs 56 12-12-2011 08:01 PM
1st tme building enclosure/need help bassknocking561 Enclosure Discussion & Design Construction Help 5 07-21-2011 03:33 PM
Ported enclosure djarmy2004 Enclosure Discussion & Design Construction Help 2 03-04-2011 10:05 AM
Enclosure Build: SA8 ported for Gabriel Ruiz Pioneer~Saturn Build Logs 33 02-21-2011 12:08 AM
Ported diamond enclosure? mikeyg402 Enclosure Discussion & Design Construction Help 0 02-17-2011 02:40 PM
